Making the RGB signal stronger?
  • Making the RGB signal stronger?
    Well I recently got a Psone LCD that only works on RGB sadly :/
    Now I have got this to work with my VGA output but the signal is a little weak and the colors look washed out as I have to put up the brightness a lot to see the image
    Now I managed to get it looking a little better by connecting the sync to the RED input buy resisting the current so it’s not to bright. “see pic”
    before sync mod
    After
    But this is just a quick fix and I would like to boost the RGB signal so it looks better.
    Dose anyone know how to do this?
    Oww and hi by the way
    Re: Making the RGB signal stronger?
    Actually, I think you just made a lot of peoples day
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
      I did?
        I did?
        you just made it known that the screens can be hacked to vga input using the rgb, always could have been possible, but I don't think I've heard of anyone trying yet.
        [H]4 Life
        I'm a lesbian too.
        I am for hire!
          btw, a lot of monitors use sync on green, don't know enough about it to know if that'll help or not
          [H]4 Life
          I'm a lesbian too.
          I am for hire!
            Did you make solder connections? Can you take a pic of where the VGA signal is inputted in to the LCD?
            Aura MR62 (F and R)
            My Current MP3s
            IamDefiler.com
              It wasn’t that hard really
              I took the RGB from pins 1,2,3 on the VGA card and connected them to RGB pins 9,11,12 on the LCD
              Then I took the H sync and V sync pins 13,14 on VGA and joined them together and then connected them to pic 6 on the LCD
              Obviously I connected ground to pin one
              And last but not lest I connected a resister to the red input then I connected the V and H sync to the resister.
              Set the card to run at 15ohm and that was it
              here it is in windows
              but i really need to know how to boost the RBG signal
                why don't you just adjust the gamma ?
                And it looks good from here
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
                  WOW you got it to work... I tried earlier this year and burned out 2 of them. What resoultion are you getting on them and how does it look with video And the last qt can you take a picture of the connection. I am interested how you got it to work without burn out the board
                    someone help the man, maybe he'll show us his work
                    [H]4 Life
                    I'm a lesbian too.
                    I am for hire!
                      dam i wonder if that would work on other lcd units
                      WINNER!!!!
                      run-on sentance comp 2002!!
                        these lcds I think have a special section for RGB from the PS One connector
                        [H]4 Life
                        I'm a lesbian too.
                        I am for hire!
                          Well after a little wiring mistake I made yesterday looks like I got it working well.
                          Some pics
                          Winamp
                          Games are always good
                          I’ll post a how to later so you guys know how to make this work
                            sweet
                            [H]4 Life
                            I'm a lesbian too.
                            I am for hire!
                              This has made my day as I have a 5.6inch composite screen fitted in my 2001 celica connected to my eden via the tv-out. Its ok with some serious larging of the fonts and use of myHTPC but something a bit clearer that would still fit would be good.
                              If you could provide step by step details on how to hook up one of these PsONE screens to a 15pin monitor cable that would help me and I would imagine lots of others
                              My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
