Lilliput EBY701 2008 VS 2009
  • Lilliput EBY701 2008 VS 2009
    hi, I noticed the only thing different is resolution. What resolution would most people run 800x600 or 1024x768? I also noticed both can be LED?
    My CarPc Blog (<This is outdated. I have updated to a fully running Carpc System)http://acurafuse.blogspot.com
    Im assuming you are comparing the new LED vs old CCFL Lilliputs. I looked at the datasheet for the two LCD panels they use inside. It seems the newer LED is actually not as bright as the old CCFL based on the data. Havent seen a side by side comparison of the two, so I cant comment on how valid this is.
