capacitive touchscreen with controller
  • capacitive touchscreen with controller
    this is interesting. A company overseas sells capacitive TS - the glass screen and controller. This is applied over a standard monitor.
    A few things i'm wondering about:
    First and foremost: if used with CentraFuse/RoadRunner/StreetDeck will the touchscreen capabilities be a lot smoother than resistive ts? Would they be close to an iPhone-like interaction?
    Second: I emailed the represantive, Jackie Golding, inquiring about price and there is a minimum order of 20 units @ $141.00 each or 80 units @ $131.00 each. Maybe we can find a vendor? Or maybe MP3Car will consider carrying this item.
    Third: I want one!
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
    That's too big for most installs - it fits an 8.4" screen (although *I* would go for one since I have an 8.4"!). However, they do have a 7 inch display size.
    You can get mp3car to allow a group buy if you arrange all the details with the manufacturer.
    Want to:
      I'd be in for a 7" if a group buy happens.
        ill be in for a 7" screen too
          Here's the product info and datasheet for this 3M capacitive touchscreen:
          3M™ MicroTouch™ System SCT3250CX
          The Clear Solution for Small Touch Applications (5.7" to 12.1" display sizes)
          http://solutions.3m.com/wps/portal/3...TouchSCT3250CX
          3M partnumber for the 7" wide screen version is: 98-0003-3112-8
              A quick search on google lead me to this
                But Digikey doesn't list any of the 3M widescreen touchscreens, but only regular 4:3 dimensions.
                The touchscreen mentioned in this topic is a 7'' widescreen format.
                  Has anyone tried this route yet? I'm about to order a "98-0003-3112-8" as soon as I can find one... Going to try and replace the Xenarc resistive overlay with it.
                  tango/dune
                  Infiniti QX4 2002 project (done!... for now)
                    Wouldn't you also need a new controller board if you switch to capacitive?
                    openMobile - An open source C# Front End (why choose openMobile?)
                    - Always Recruiting Developers -
                    Like what you see? Donations are always welcome
                      Yes, new controller as well. I found the same type 3M panel (but non-wide) on mouser.com. The panel and controller were about $90/ea. I just can't seem to find the wide 7" part. The controller appears to be the same.
                      I know it's been done before but I'm going to call 3M tomorrow. If it turns out the only way to get "98-0003-3112-8" is through bulk order, you can add me to the list.
                      What do you guys think about this combo?
                      Panel: 17-9131-203 (http://www.onlinecomponents.com/buy/...EMS/179131203/)
                      Controller: EXII-7760UC (http://www.onlinecomponents.com/buy/...S/EXII-7760UC/)
                      tango/dune
                        Any updates?
                        Dan from Minneapolis
                        1999 Volvo V70R
                        Jetway J7F2WE2G, USB Creative Soundblaster, RoadRunner, Holux BT GPS, 3M Capacitive Lilliput, etc.
                          Yes, I'd be interested on this.
                          Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
                          Skin: MetroSex on the Beach preview
                          07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
                            I'm interested in this as well.... however I'm looking to replace the TS on a 10.4"
                            I'm stumped on something though. At the 3M site it mentions that a controller is included with the panel.
                            3M 10.4" Capacitive Panel
                            Under controllers available it lists one and that it is included. Is that all I would need to replace my resistive panel, or would I need this controller as well?
                            3M MicroTouch™ EX II Series Controller
                            And if so, what sort of connection/cable would I need to hook to two up.
                            BTW
                            I've found a reseller that will do single orders here (at least for the two pieces I'm looking for anyway)
                            http://www.allamerican.com/
                            Orbserver
                              The fact that it says it comes with a controller and that it's "HID-USB" leads me to believe you don't need anything else. That distributor should be able to confirm what exactly comes with that item. The trick is to make sure the overall panel dimensions (both physical size and sensor area) will work for your display and bezel.
                              I haven't made the jump yet to get one of the 3M panels as I really want an all-in-one unit. I'm also looking for projected capacitive as surface capacitive can wear down over time, or so I've read.
                              I found the same site but they didn't have in stock the stuff I was looking for. If anyone here moves forward with a 3M panel, let us know how it turns out.
                              tango/dune
