Problem with a 40x4 Parallel Port LCD
  • Problem with a 40x4 Parallel Port LCD
    Hey guys,
    I've had this 40x4 parallel port LCD for a couple years now. In my original mp3car that ran Windows 98, it ran fine with the LCDisplayer Winamp plugin.
    I've recently installed Windows XP for faster boots, streamlined 802.11, and hardware installation. However, Windows XP does not support direct and constant Input Output (I/O) to the parallel port, and therefore I get an error message whenever I try to start LCD Output from the Winamp Visualizations options.
    Has anyone had any luck in getting LCDisplayer or any other LPT accessing driver or software to work under Windows XP?
    I've tried DriverLINX, but it wasn't very useful. I also installed the Paraport driver from www.paraport.net, but that just gave me a different error message. (and yes I've searched the forums)
    Any help is greatly appreciated!
    HomePage and Mp3Car Setup
    Dunno if this will do the trick, but thats the "usual" answer to direct I/O problems for MS os'es since win 9x.
    http://www.markuszehnder.ch/projects...n/port95nt.exe
    Hope it helps. Check the plugin too, it really rocks, especially with the 40x4 that you got.
    http://www.markuszehnder.ch/projects...gin/index.html
    cvi
      yes you need port95nt like above
      [H]4 Life
      I'm a lesbian too.
      I am for hire!
        I've installed Port95, but how exactly do I use it? It comes with two executables and no explanations as to how they're used.
          cvi
          I've tried downloading that, but it looks like a bunch of C++ files that need to be compiled? Where is the download for the actual Winamp plugin? And I didn't see any support for a Parallel port 40x4 LCD.
            It has support for parallell 4x40, take my word
            My cars
              But where is the download link for the winamp plugin?
              There's just a bunch of compiler files in the download page? Maybe I'm not seeing it?
              Can someone help?
                v0.6a binaries
                http://cesnet.dl.sourceforge.net/sou...n_bin_0.6a.zip
                My cars
                  Alright thanks!!! So what do I do with the Port95nt program after it's installed?
                  Does it work automatically after Port95nt has been installed?
                  Thanks for all your help btw.
                    I dont know, I plan to run 98lite on my mp3player so I haven't dug into it... but someone else will surely help.
                    My cars
                      after port95 is installed it should work to just run your lcd program of choice.
                      ps, im running a 16x2 parallel lcd on my windows 2k computer (not my carputer).
                      Project AutoBoxen: Coming along, almost ready to hook up in the car.
                      Celeron 500, 192mb ram, 8gb hdd, other stuff.
                      '91 Mazda 626: Its free, so ill use it.
                        Ok...
                        So I installed Port95, but I still get that error message.
                        But here's the funny thing. I'm running an LCD Winamp plugin that I used with Win98 just fine. After Port95 was installed, it made no difference. So, I installed and ran the other Winamp LCD plugin that has settings for those 10 or so different LCD's, none of the LCD selections worked for my 40x4 parallel port LCD.
                        However... After I tried running the plugin from
                        and getting an error message that it couldn't find my LCD, I ran the original Winamp LCD plugin that worked with Win98, and it worked just fine!
                        At first I was really excited...until I realized that it only works, after you try running the newer Winamp LCD plugin and getting the error message.
                        This is an incredibly strange problem. You would think the older LCD Winamp plugin would work fine after Port95....AND IT DOES...only after you try running the newer plugin.
                        Any ideas? I hope my explanation wasn't too confusing.
                          You gonna use xp in your setup? otherwise, do as I did, dont bother
                          My cars
                            Yeah, WinXP streamlines with my wireless and has other benefits that Win98 can't compete with.
                              Can anyone else suggest anything?
                              -Thanks
