re: Best way to bond plastic?
  • re: Best way to bond plastic?
    hi, I need to best way to glue or stick platic together? I cannot used super/gorilla glue I need a paste like liquid to cover a big area 1x2 inch or larger. No sanding needed just need it to stick.
    My CarPc Blog (<This is outdated. I have updated to a fully running Carpc System)http://acurafuse.blogspot.com
    silicone
    2007 Toyota Tundra Double Cab SR5
    >"Say what you mean and mean what you say"<
      Abs cement will bond permanently most plastics together.
      My 2007 Yukon XL setup. http://www.mp3car.com/vbulletin/show...64-5000-a.html
        Permatex makes a plastic cement that is like a 2 part epoxy, but is creamy coloured. It works REALLY REALLY well.
        http://www.amazon.com/Permatex-84115.../dp/B000ALBZK8
          If it's abs plastic, you can buy abs cement, or make it yourself with abs shavings + acetone. Also maybe look into jb weld? Silicone is a bit weak.
            I went with the convient way. I went to the nearest autoparts store and purchased JB-Weld Stick. Is currently working VERY well and I like it. Is also easy to applied. Think like putty/clay/play dough and you mold it into the bezel and screen.
