Fixed: Lilliput EBY701 - vertical line across LCD
  • Fixed: Lilliput EBY701 - vertical line across LCD
    Hi!
    I've just purchased a brand new EBY 701 with transflective coating. The screen is bright and clear, but there is a solid blue line going across the screen from top to bottom on the right side (about 3cm or a little more than an inch from the edge). This line is visible as soon as the LCD is powered up. Even with no input signal.
    Anybody else seen this problem on a Lilliput EBY701? Any suggestions on how to fix it? I could always return the monitor as it has a warranty, but if it is possible to fix I would prefer that.
    I am an electronics and computer software professional.
    Fixed! Replaced LCD panel.
