Programming Code for Lilliput 629GL
  • Programming Code for Lilliput 629GL
    I just got my new 629GL (DVI input) and the 588998 code does not work on this model, so I was hoping someone would know how I can get into the settings to enable the Auto-on so it will power up when it receives video signal.
    Me too, the same 629GL DVI and 588998 nothing.
    Anyone pleaseeeeeeeeeee ???
    2008 Honda Civic LXS
    Zotac 630i
    2Gb DDR 800
    500GB
    Lilliput 629 (DVI)
    WinXp Pro (Customized)
    Holux
    M2-ATX
    3D Connection
    Centrafuse
      I found !!!!!!!
      Please find the instruction below to turn on 629GL-70NP with DVI when power is connected.
      1. Plug in the power. Make sure a video or VGA signal cable is connected and the video signal can be received when the monitor is turned on.
      2. Press and hold power button for 5-7 seconds, release the power button and press it again immediately to turn on the monitor. Press menu button, the factory mode should display.
      3. Press menu button to select 3rd page. Select power state mode by “> button” and change the value of setting from 0 to 2 by pressing “Vol+” button.
      4. Press menu repeatedly to save and exit.
      Thank you.
      _Parilla_
      Zotac 630i
      2Gb DDR 800
      500GB
      Lilliput 629 (DVI)
      Holux
      M2-ATX
      3D Connection
      Centrafuse
