Datalux - VGA Cable Power is the Pin + ?
  • Datalux - VGA Cable Power is the Pin + ?
    Hey Guys,
    I have searched and couldn't find the answer to this seemingly simple questions...
    I have a Datalux LMV10 without a power cable. I am going to make my own and I need to know if the cable should be inside positive (outside negative). Is the pin on the Datalux cable positive? I looked on their website and can't seem to find that info...I found it for the S12, which says "Mates with Switchcraft model 760 jack or equivalent; barrel 2.5mm ID 5.5mm OD outside neg."
    Any help would be appreciated!
    - Jeff
    95 Mustang GT Convertible
    87 Mustang GT Convertible
    My Project | Let's Go Mets! | SCT Tuners
    Project Status [===#===] [Bezel and dash creation]
    hmm the power for my screen is comming from the vga to tft controller.
    Does your screen turn on at all? You are kinda unclear, I would gladly help you out seing I have a datalux setup.
    What im curently listening to.
    My complete carpc setup
      Hello Osirisdon,
      Thanks for the response. The Datalux is intact - still in its case. The VGA cable from the case terminates in standard 15 Pin fashion, however, there's a power connector built into the top of it.
      Check this page out to see a small B&W pic of what I'm talking about:
      http://www.datalux.com/generic/manua...structions.pdf
      Thanks!
      - Jeff
        LOL...it says it right there
        OUTSIDE NEG = OUTSIDE NEGATIVE
        and inside positive
          Hey Matty,
          Yes, that was for the 12 in. version - I wanted to make sure the 10.4 inch was the same before I go hooking it up that way and blow up my precious controller inside.
          I know outside neg. = outside negative
          - Jeff
            its 12vDC, I have the same exact lcd and its 12vDC oh wait I already said that.
            If you have any other questions contact me via AIM more than willing to help you out.
              Originally posted by jzgt
              Hey Matty,
              - Jeff
              Im pretty sure that the connection standard is outside negative. Wouldnt know why they would change it for this LCD
                I have the 10.4 inch and its outside neg mkay?
                  Thanks for checking. I figured they wouldn't change it but I'd rather not open it right now and I didn't want to blow it up when I was sure someone else out there had one and could check for me.
                  Thanks for the help!!
                  - Jeff
