Old Xenarc touchscreen problem
  • Old Xenarc touchscreen problem
    Hey all. i did a little searching and didn't find anything helpful so I thought I'd create this post.
    I have a bit of an odd problem and don't know enough about touchscreens to pinpoint what part of hardware is probably faulty.
    I have an old Xenarc 7". about a year ago I fried my motherboard. I pretty much just let it go (i usually ride my motorcycle anyway) until recently. I replaced the board and restored the OS from backup. Everything is working except for the touchscreen.
    Now, when I plugged in the usb for the touchscreen, the device registered and the drivers loaded. So, I would assume the problem lies with the hardware somewhere.
    Would the most likely faulty hardware be with the actual touchscreen or with the touchscreen controller? It would seem something is working because when the USB was connected, it registered the device and pulled the drivers.
    Any help would be grately appreciated.
    And the problem is.......?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
      The touchscreen doesn't work. The pointer doesn't move at all.
        Oh. Does it show up in the Device Manager fine?
        Ampie Case
        256 MB DDR2 PC5400
        M2-ATX-HV
        2005 Honda Civic
          yep, it shows in the device manager as it should.
