Monitor flicker instead of turn on
  • Monitor flicker instead of turn on
    Hi all, I have a LinITX Plus 7" Widescreen VGA/Composite Monitor (with touchscreen) monitor in my install, and when driving it usually works fine. However sometimes when I first fire up the monitor just seems to flicker as if its powering on and off, and doesnt go to the VGA output. If i disconnect and reconnect the power it comes on fine - any clues?
    bad/loose/corroded power connection?
      Ill check that out, many thanks!
