GPS LCd > PC
  • GPS LCd > PC
    Hi, Im a REAL noob at this, so ill ask my question quickly.
    What kind of plug is this, and are there adaptors I can purchase to connect it to DVI/VGA or TV-out(s-vid/composite) ?
    All I know is that it supplies power and data. I've done extensive searching and can't find anything like it....I'm assuming it's quite old..?...
    All help apreciated
    Model #'s or serial #'s?
      I couldn't find any information frmo the model numbers on the back of the LCD.
      But here you go.
      FA3350590
      TR-4LC2
      And the rest is in japanese
      Maybe someone here can read japanese, so here's a pic of the back.
      Sorry it's so blurry.
        Just found this; Doesn't look exactly the same, but is very similar.
        N-DV2300 Navigation System Specifications:
        _
        Power Supply - 12v DC
        Current consumption - less than 2.5A
        Dimensions - 178x50x170mm (WxDxH)
        Weight - 2.0kg
        _
        Reception frequency - 1575.42MHz
        Reception sensitivity - -130dBm
        Reception method - Parallel 8 channels
        Receiving code - C/A Code
        Channel system - Multichannel
        Channels - 8
        GPS Satellites received - 8 max.
        _
        Guide Map - DVD SDAL format
        _
        Picture Output - RGB (navigation screen) / NTSC 1.0Vp-p, 75ohms, RCA pin jack (navigation screen)
        _
        Analogue audio output - Monaural 1ch 1.5Vrms (1kHz, 0dB)
        _
        GPS Antenna
        Type - Microstrip Planer
        Dimensions - 42x14x50mm
        Weight - 120g
        _
        Remote Control
        Dimensions - 41x40x155mm
        Weight - 65g
        _
        Infrared Receiver
        Dimensions - 34x17x22mm
        Weight - 60g
        Basically that still doesn't help me much, but it could help someone help me
          Damn, this is the kind of gadgets I like to get my hands on!
          It is perfect for the hobbyist.
          If you are handy with a soldering iron and a multimeter, PM me and I'll give you some tips on how to figure out the inputs/outputs and power connections.
            I fonud out what kind of plug it was last night. Its an old Atari ST monitor plug.
            Heres the ST > VGA converter http://gem.win.co.nz/mb/atarihw/stvga.html
            And I'll need a DVI > VGA to go with it.
            Thank god because I couldn't be worse with a sodering iron.
            Thanks for all the help everyone. Hopefully there is a place in NZ that sells these ST>VGA adaptors.
            I'll post back soon with pics on how it runs.
                That may be the same connector, but that adapter is not gonna do **** for you.
                [H]4 Life
                I'm a lesbian too.
                I am for hire!
                  explain, because that doesn't exactly say alot.
                    It's highly unlikely that LCD has the same pinout as the ST, even if it does use the same connector.
                      I have guides that show me how to convert the Atari ST monitor cable into SCART and VGA. (however I have no soldering skills)
                      All the lines carry certain signals which seem easily rerouted.
                      Are you telling me this because you know or because you *think*? It all seems pretty pessimistic to me.
                        Have a look at this.
                        http://www.howell1964.freeserve.co.u...i_ST_Video.htm
                          Here's some of the inner workers. There is another connector inside which may look familiar to somebody.
                            I don't think that ST->VGA adaptor will work at all as you are going in the wrong direction.
                            That adaptor allows a video source that originates from a ST style output to be plugged into a standard analog VGA monitor. What you are trying to achieve is the opposite i.e take a std vga output and connect it up to a monitor that accepts an ST style monitor input
                            My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
                              Yeah sorry :/ I've got 2 threads asking about this and I said that in the other one but not this.
                              Nevertheless is would still help if I found either or.
