Need Help w/ Broken wire Location on Lilliput7"
  • Need Help w/ Broken wire Location on Lilliput7"
    I have an older 7wide-vga color lcd tv that a few wires broke off the board and I need to know which wire goes where. The plug connects to the board and the gray and green wires broke off the board. I am uploading a photo and you can see the two spots missing a wire connected and I need to know which goes where. Which goes next to the black
    I also have a USB controller cy-4w-usb-03 that has the wires coming off the plug then there is a connecter that plugs into the board. Where do the wires coming off the controller plug go?
    ANY help is appreciated.
    There is no serial number or model on the screen. Its says 7WIDE VGA COLOR LCD TV on the back and I know its a lilliput.
    I would just take it to an electronics repair shop, they should be able to figure it out.
    carputers
      Yea, Im going to pay some jerkwad major bucks to solder two wires. I expected better responses from this site.
        I understand where you're coming from. I guess as a last resort you could take it to a shop if it's that important to you and if nobody is able to help you out on the forum. I'll post a better answer next time.
        carputers
          I really didnt mean any offense but just frustrated. Thanx
