ps2 cable of TFT car MONITOR ...HELP HELP
  • ps2 cable of TFT car MONITOR ...HELP HELP
    dear all i have a TFT car monitor from boschmann and it has a ps2 cable ,,,, my car DVD player has AV ( composite) output can i operate it using external 12+ volt power supply and using the av signal from That DVD ..IF YES PLEASE ... show me the PS2 pins ....
    thanks
    Sounds to me like its not a PS2 port, rather an SVideo. You should simply need a composite to SVideo adapter, but don't quote me. Can you post a picture of the port you have?
    Dirty Rockstar
    http://i2.photobucket.com/albums/y19...pronnarrow.jpg
      yes you can use a adapter as long as the two signal are either analog or digital.
      English is not my first language so if I say something weird just say it to me and i try to be clearer :) :)
        no sir am sure its like PS2 it has 6 pins,,,and i solved the problem i cut the cable and i obtained the following
        red : 12 +
        black : ground
        yellow coaxial : video but the shield must be connected to the ground
        and other colors i think for video 2 and audio
        note : u have to install a voltage regulator 12v+ consist of L7812 and 100uF and 10uF as a power supply to the TFT screen from battery dont forget the switch
        these type of TFT screen manufactured to be connected to the boschmann car DVD player we can operate it as a TV ( to have 12+ supply and video composite )
        just do that iam sure its works
        i am connecting a camera to the backwards light and the video to the TFT screen its working properly will send the pic's and video upon request
          just to clarified my point the pinout of s-video port and a ps/2 port is the same, here an image of the
          PS/2
          and a
          S-Video one
            man see the pic's once again ,, the s-video has 4 pins the ps2 has 6 pins..
            regards
            engineer tamer
            design and site engineer at accurate technologies company -amman -jordan
