619 vs 701
  • 619 vs 701
    Ok, I have dug around a bit but coming up a bit dry....
    How does the Lilliput 7" EBY701-NP/C/T compare to it's older brother the 619?
    I'm asking since I came up with a old "new" one but after taking it out of it's wrapping I find that it's a bit dark even with playing with the settings and viewing in a in-door environment.
    Or am missing something here?
    Depends on when they were made.
    Both models had "old" and "new" versions.
    And, as you probably already guessed, Old = CCFL backlight, and New= LED backlight.
    The New versions both use the same exact LCD panel inside but the Old versions used 2 different LCD panels.
      Thanks!
      Now I just have to check the unit for itself build date.
