wiring up a pc vga out to tft laptop screen
  • wiring up a pc vga out to tft laptop screen
    Hi
    Don't post a lot but have been reading avidly!
    I got a 12.1" tft screen as a replacement screen for a compaq presario laptop I was fixing - now the laptop has died on me so I've not got a nice tft panel and invertor and basically everything I can strip out the laptop....
    Can I wire this up to and use it for a in car screen? I'm planning to integrate it into a boot install - not an on dash one (basically for showing off purposes.... is it gonna be possible to wire it up so I can plug it into the pc video card?
    Can it be done... or am I dreaming and should just put it ebay.....
    Kenny
    Click below to find your answer:
      Been there done that - before I posted - if you find me the answer would be helpful - cause I tried and couldn't find it.
      Kenny
        Re: wiring up a pc vga out to tft laptop screen
        search for laptop screen controller
        My cars
          This question is asked a lot here and everybody is a little tired
          Here is the same question (few posts down): http://www.mp3car.com/vbulletin/show...threadid=13982
          In short - it is possible to do what you want but maybe a little challenging. The laptop LCD screen works from a controller that is built into the laptops motherboard. This means that it will not work without being connected to a laptop. The challenging part comes in when you'll start looking for a controller that will work with the screen. Do you know what brand/model # of LCD panel that's in your laptop? Find out and start searching for a data sheet that will have all the details about the panel. Then you will need to find a controller.
          This is not going to be easy but possible if you're persistent. Most people abandon this idea and get something that already works. Give it a try
          Armen
          http://www.digitalww.com
            http://www.mp3car.com/vbulletin/show...threadid=13984
            That's going to be your cheapest route. Make sure you find a datasheet for your lcd before you spend any money on it.
            >\\MP3G60//<
