Lilliput 869GL-80NP/C/T 8" Inner Dimensions???
  • Lilliput 869GL-80NP/C/T 8" Inner Dimensions???
    I have looked all over this forum and on Google for the inner viewable dimensions for this screen. I need to know so that i can tell if I am going to need to re-fabricate my 2DIN dash or not. If anyone has this info it would be greatly appreciated. Thanks, and the link to the specific LCD in question is below.
    http://store.mp3car.com/ProductDetai...ctCode=MON-110
    Expert IT Administrator/Technician
    A+, Net+, Sec+, MCP, CEH
    In-case anyone is interested, I received the dimensions from Lilliput. They are 19.2cm W x 11.6cm L (7.6in. x 4.6in). That is for the LCD Display itself without the case.
      Can you verify dimensions these yourself, they seem a bit big.
      I thought they where the same dimensions as the lilliput 889GL?
      Inner screen - 175mm x 107mm
      http://www.mp3car.com/vbulletin/lcd-...-included.html
      Just asking because i'm interested in getting this screen myself.
        FYI - I just contacted Lilliput to get exact dimensions, here is their response:
        The size of LCD panel is 192.8(W)X116.9(H)X6.4(D) mm; and active area (Display area) is 176.64(W)X99.36(H) mm.
        If you're looking to fill up a Double-Din slot (180mm X 100mm), this should do very nicely.
          I wanted to add some follow up here - I'm not sure if this is just the way my dash kit is, or if they are all made this way (I suspect all of them are the same) - but the dash kit opening is -NOT- 180mm x 100mm. At least not on the back.
          In other words - if you're looking to get an 8" touchscreen inside the dash, you're going to have to fab something yourself. I think I'll be taking my dash kit and cutting it up and sanding it down. Lets hope I can make it look nice.
