Auto powering innolux LCD
  • Auto powering innolux LCD
    I have an LCD build on innolux matrix innolux AT080TN03 ( ) with innolux controller ( looks very similar to but slightly different in firmware )
    How can i make it power on automaticcaly after connecting to power supply?
    Now it goes to standby mode on AC restoration and can be turned on by button or remote, but I want it to be on right after AC restoration without touching any buttons.
    I use M2-ITX power supply modification (M2-ITX). Motherboard is powered on by signal on its J4 connector. Connecting J9 connector to LCD power button doesnot help, 'cause J9 not only makes circuit short, but also has potential about 3V.
    Lilliput programming mode does not work for this LCD as remote has no buttons with digits and controller's firmware is distinctivly different
    PS: Controller is not innolux, but realtek RTD2660PD based Shenzhen Feelworld
      not a really a solution, but a work-around:
      use a momentary relay/transistor to press the button when the acc line goes hot.
      or talk to member Curiosity about building a custom controller that will do what i listed above..
      next project? subaru brz
      carpc undecided
        Already thought about it, if there's no software solution should install optical pair on power supply J9 connector to get rid of 3V
        However, maybe anyone know how to get to factory/engineering meny on this controllers?
