How to fill the Tm-701L Screen on a EPIA-M
  • How to fill the Tm-701L Screen on a EPIA-M
    Well as we all know filling the screen on the 7Ē TM-701L can be a bit of an issue, but this is how I did it:
    (My system: VIA EPIA-M9000 latest BIO, TM-701L screen)
    1. Right click, and go into your display properties
    2. Set your display resolution to 800x600
    Yes, this will make your icons and text hard to read but we will fix that.
    3. Select the appearance tag
    4. There is the ďItemĒ box, open it and you will see a list of items that can have their font and icon size changed.
    This will change all Iconís, menuís, text, and stuff on your comp so change them independently of each other, or it can get messy
    5. Go to the 3S tag in the advanced tag, and select the TV out advanced tag. Move the picture until you have it centered.
    The only snag Iíve see so far is that when running ME it can be hard to hit the little red button in the upper left corner
    Anyone else have this problem when following the directions above?
    I followed everything, and it all worked great. everything is centered.
    but when I shutdown properly and restart, all the settings I just made are lost. I have to do it everytime my carputer boots up. ??? very frustrating, your wisdom is much appreciated
    Grand AMplifier Project 1.0:
    http://drive.to/cliffsgrandamgt/
    http://www.astallaslions.com/carmp3/
    -Eden 800 mini-itx motherboard
    -5.6 NTSC TFT-LCD
    -80 gig hard drive
    -128 MB RAM
    -MPBS1 DC-DC PSU
    -PB Remote /w Girder
    -Media Engine & Windows XP
    -Playstation II also added
    -Steering Wheel Buttons modified for Control.
      i have had that problem a few occasions in the past,
      maybe your computer isnt shutting down properly before the power is killed
      do a restart and see if it still happens
        I have tryed restarts and it happens, its really weird. it's driving me crazy!
        is there anything I can do?
        -5.6 NTSC TFT-LCD
        -80 gig hard drive
        -128 MB RAM
        -MPBS1 DC-DC PSU
          I am having this problem as well, after system restarts, the composite settings was lost.
          MediaCar
          Girder with Igor plugin
          EPIA-ME6000 w 256MB DDR
          Morex 55W PSU
          12VDC Regulator
          IBM DJSA-220 20GB
          90% completed in a plastic case (8"x10"x2.5")
