Capacitive touchscreens?
  • Capacitive touchscreens?
    Hey
    I was wondering if there are any capacitive in the 7" area.
    Thanks.
    Try searching. I just spent 2 minutes searching for this and found your answer. Maybe someone else will spoon feed you, but with the ease that I found it, I'm pretty sure you didn't even try.
    Tidder
    Try RevFE
      Does anyone make a pre-assembled capacitive 7" touch screen?
      I just tried searching and all I could find were touch kits for normal LCD's, definitely don't want to be screwing about with adding touch to a non touch screen or replacing resistive with capacitive.
        I looked around before making this thread.
        http://www.mp3car.com/vbulletin/sear...=7423334&pp=25
        AFAIsee, I only see 2 threads which have information:
        NEC 8.4" Transflective Solution - Custom Kit (first post didnt even say if it was capactive)
        Synaptics announces new range of multitouch capcitives... (Ill ask in that one as he said he had one but didnt say which one)
        So maybe the one that needs to look around is you....The question has been asked last on 02-28-2010 so..........I dont know...........maybe things have been updated.
        I think you are the one that needs to search a bit better before trying to say you are spoon feeding me...
          I was searching for this very answer and all I could find were threads flaming people for asking instead of answering the question. From what I can tell there aren't any factory options, but you can pick up a EBY701 that someone pre-installed a 3m capacitive touchscreen in on ebay. It's surface not projected so no multitouch.
          http://cgi.ebay.com/NEW-LILLIPUT-EBY...ht_4053wt_1135
          About the only preassembled option i can find....
            This is the thread I've been keeping track of, they seem pretty keen to find an answer but there still isn't much out there.
            http://www.mp3car.com/vbulletin/lcd-...ml#post1423724
              For some reason I really doubt this. I'm pretty sure my search skills are right on. You are the one that needs to look around, not I.
              Read thru This Thread then you'll be up to speed with the rest of us.
              Apparently I search a lot better than you do. If it's not what you are looking for, perhaps you should get better at asking questions.
              @Sicarius123, I don't think there are any ready-out-of-the-box solutions currently on the market, kind of a bummer. There are a few outfits out there that are modding with capacitive and reselling, I'll search around again and post some links.
              Tidder
              Try RevFE
                He is asking for a display with the controller from what I can tell in the first post. Im asking for a prebuilt touchscreen.
                2 different things. Is english you native language? (Seriously asking)
                  Here is a link for a prebuilt Capacitive monitor.
                  http://cgi.ebay.com/NEW-LILLIPUT-EBY...item2a079bf5b0
                  Also available in a bonded high bright.
                    Ah, so that's you. I see that you apparently sold the 10.4 with capacitive I was thinking about. I was about to ask you about the backlight upgrade info you did to that screen. Are you going to make more of them or was it a one-off?
                    Any news on multi touch capacitive?
                    Worklogs: 08 Sequoia Platinum Carputer (In Progress!)
                    Skin: MetroSex on the Beach preview
                    07 Infiniti Fx35 (done!) & 06 Infiniti M35 (gone...)
                      Funny you ask about the 10.4.
                      One of the buyers asked if I could build him a second one. So, yes I will be making more.
                      I have the parts on hand to make at least 2 more, not counting the cap. touch kits.
                      Want one?
                        Not sure yet, but thanks. I know that screen is a great screen, but with the upgrades you've made, how does it compare to you best Lilliput bonded high bright you mentioned above? A bit worse, about the same or better?
                        I really like something better than 80/80/80 viewing angles, although it's better than my 30/30/30 on my el cheapo Xenarc 700TSV.
                        Any chance of you getting your hands on an AFFS+ screen, only in 10.4? Like this one. A screen like that, with the proper backlight (no need to save battery once it's out of the tablet) with a capacitive touch panel, is all that I need.
                        I know motion computing has a 10.4 AFFS+ screen, and it's been touted as the best screen ever for outdoor use, here, here and here (with video).
                          So...tft_lcd_org...how do they compare (your best Lili and the 10.4")? worse, the same or better?
                            I really can't compare the two, since they are entirely different setups.
                            The Lilli has a 450nit LCD with factory installed enhanced films, with a bonded capacitive touch screen.
                            The 10.4" features an XGA panel that has been placed on a custom made light box. The box was made by xxxxxx. (Sorry, trade secret).
                            It also has an upgraded film stack. But, @ 1400nits (manufacturer, pre-touch rating) the brightness easily overcomes any issues that are cleared up by bonding with the Lili monitor.
                            If you need RCA video, reverse cam, remote, and a name brand on your gear, then buy the Lilli.
                            If you need brightness over added features and have the room, consider the 10.4" as the better choice.
                            Each one has strong points, and some would say each has their downfalls.
                            I personally would go with 10.4" just for the size, but then again I would install a 22" screen in my dash if I didn't need the HVAC and cup holders in my van.
                            Either way, you would be buying a modified, quality display that will serve you well in your vehicle.
                              Thank you. It's very tempting - specially because it's a boe-hydis panel..., but for my application I would need to build an enclosure for it, and one as thin as possible - I'm custom building a vesa mount and it would be "hovering" over my center console, so the back would be exposed etc. If I go that route I would probably buy a broken 10.4 rear entertainment screen or something like that and use the case. But the controller would be inside the console, 4ft away, as I indicated in a previous email.
                              I don't need reverse cam or RCA input or anything like that, just dvi or hdmi.
