source for longer ribbon cables for 669GL
  • source for longer ribbon cables for 669GL
    Anyone know where we can get longer 2x30 ribbon cables for between the control board and the LCD of a Lilliput 669GL.
    Same goes for the 4 pin touch screen ribbon.
    Somewhere around 10-12" would be ideal.
    from the Almost everything you wanted to know about the Lilliput 669GL topic:
    " The 669GL-70NP/C uses a 250 nit Innolux AT070TN82 v.1 (referred to as TN82 v.1 moving forward) with 500:1 contrast ratio and 60 pin ttl connector "
    > TTL, so its risky to add 1 more connector and longer cable - You can give it a try, but it will be expensive and nothing guaranteed. the LVDS is much more stable, can be extended to longer cables, but its too difficult to convert it to LVDS and back to TTL...
    "case": Skoda Superb Elegance 1.8T
    Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
      What FPeter said. Its not going to happen. There are a few LVDS to TTL converters on the market but they are normally geared towards a specific panel and are expensive.
