Looking for an 8.4" 16:9 Display
  • Looking for an 8.4" 16:9 Display
    Do these exist? With some rough measurements and calculation, 8.4" would fit into a double din whilst not having any borders etc. Any one else come to this conclusion?
    Measured diagonally, a Double DIN opening is 8".
    Assuming you can find an LCD panel that has a paper thin metal frame, you would be about 7.6-7.8" at most. AFAIK, no such LCD size (VGA that is) exists.
    7" is about all you are going to fit in a D.D. opening.
      the double din standard is 4" tall by 7" wide..
      next project? subaru brz
      carpc undecided
        OK, sorry. The double din opening measures 8-1/16" diagonally.
        My fault, I missed the 16th of an inch while doing the math in my head.
        Won't happen again.
          i wasn't correcting you, just adding the specific L x W dimensions of the opening.. because there could be many panels that have a 8" diagonal measurement, but less that measure closer to the real size of a double din opening.
          and don't lie-- it will happen again, your just in denial (don't worry about it, just a couple of weeks ago, i was off by over a hundred feet on a wire run--a 1/16" is nuthin..)
          carpc undecided
            You're right, I am in denial!
            Good point though. A diagonal measure of 8.whatever could look quite different depending on the L/W.
            Like those 12" visor displays on ebay.
            http://cgi.ebay.com/NEW-PAIR-BLACK-1...item33617e6a65
