Mini Touch 700 doing my head in! Stupid 800x480
  • Mini Touch 700 doing my head in! Stupid 800x480
    hi all,
    let me just say i've always wanted to build a car pc, and have been doing my research for a while now, but i've come across a bit of a problem with it!
    i can not for the life of me get the screen to output 800x480 properly! I've tried 2 different desktops and a laptop and whenever i 'force' the screen to display 800x480 all i get is a mess! Well not a bad mess, but its not the 1:1 pixel count that i wanted!
    the chipsets i've tried so far include SiS Mirage graphics, Intel 4500MHD, and the new AMD Fusion (6310)
    800x600 doesnt look too bad, but i thought they would be no problems getting 800x480 to work!
    Even tried powerstrip but that doesnt seem to help either!
    Any advice?
    Simply: get a proper monitor - if you can find one I have a Lilliput 629 and having the same issue. I have read through various forums and the conclusion was always the same... These (not even so) cheap Chinese monitors just can not handle their own native resolution properly.
      I have a MiniTouch 700 and it displays 800x480 no problem on my intel d945gclf2. It aligned perfect just by using the auto adjust settings. I know its not any help, but 800x480 went smooth for me.
      1997 Acura CL (Capacitive Touch, GPS, DVD, HD Radio, Backup Camera)
        could you please do me a massive favour and install powerstrip, go into advanced timing options under display profiles and write down ALL the settings used in there, (about 12-15 settings)
        thanks
          Some of the cheap monitors scale 800x600 just fine. Circles remain circular. Have you tried running your frontend with the resolution at a standard 800x600 and seeing what it looks like? I never messed with custom resolutions since my super cheap monitor did well scaling it itself.
          1.9in x 2.9in -- 47mm x 73mm
            yeah i know 800x600 displays ok, but i'd like 800x480 if possible.....
            m2x0p9x could you PLEASE install powerstrip (no its not porn!) and could you have a look under advanced timings and write down all the settings and post here?
              Heres a list of Settings i need for the Mini touch 700 to get working at 800x480!
              RAMDAC Pixel Clock:
              Horizontal Geometry
              Scan Rate:
              Active:
              Front Porch:
              Sync width:
              Back Porch:
              Total:
              Verticial Geometry
              Active:
              Front Porch:
              Sync Width:
              Back Porch:
              Total:
              With this information i should be able to get it working....
              thanks
                Maybe you can find out what kind of panel the monitor has, and google for it's spec. sheet. That should have the info you need.
                  I have working Linux modelines for this monitor, if that helps. I think these may be the numbers that you need.
                  Modeline "800x480" 31.746 800 864 944 1000 480 508 511 525 -hsync -vsync
                  Wikipedia lists the numbers as follows:
                  pclk hdisp hsyncstart hsyncend htotal vdisp vsyncstart vsyncend vtotal
                    thanks for the settings but didnt help! I'll keep on digging for more modes...
                      Am now starting to think its a faulty LCD controller board, but am happy to try other settings!
                        @wesley
                        Sorry I didnt follow the thread after I posted. Just found it again after a search for "800x480". I have no screen is my car right now as im working on a new bezel for my MiniTouch, so I wouldnt be able to get powerstrip on there for you. I have been listening to the same playlist for the past week, lol. But dont feel bad, im in the same boat now as im working on my new setup which is a Intel D510MO and I cant get 800x480 running on the MiniTouch either. Guess my D945GCLF was just ready outta the box.
                        Anyone else have any luck with Intel D510MO and a MiniTouch?
                          @m2x0p9x
                          All is cool, i gave up in the end and i run it at 800x600!! So much for a 800x480 huh?
                          Would of been nice to run it at its native resolution, but after ripping my hair out and leaving it sit on my bench for 2 weeks whilst i pondered solutions i gave up and settled for 800x600.
                          i run it in Bybyte double din enclosure with an Asrock E350M1-USB3 Mini itx board and it runs great! (the usb3 on this board is complete rubbish and is disabled!)
                          I just wish the LCD had more compatibility with onboard graphic chipsets and stored the correct data in the EDED or whatever its called! (the ROM with built in timings on the LCD board)
                          Next time the enclosures out of the car im going to try it on a few more chipsets that i've acquired!!
                            I have that same board and same screen. I had to go into the catalyst control center to set the resolution to 800x480. Nothing else would set it. Got to ati's website and download their driver finder tool. Let it run and install the latest drivers. When it is done go into the catalyst control center and change the settings there. Hope this works.
                            Audio
                            Front / Rear RE Audio RE6.5C + RE Audio DTS-500.4
                            Sub RE Audio SEX10D4 + RE Audio DTS-1500.1
                            Carputer
                            MOCOSO Case + MiniTouch DD + Asrock E350M1
                              will try with the latest catalyst, but i have my doubts! to be honest i suspect its something in the LCD driver board BIOS or something along those lines thats preventing it!
