No display on Lilliput 8"
  • No display on Lilliput 8"
    So I've been setting up the software on my Lilliput for a few days to get it perfect before I put it into the car. Today I go to use it and there's no display. Not even the "No Input Detected" blue screen that I'm used to seeing. The power light is red and I can turn it on to make it turn green but no dice.
    I opened it up and all of the connectors are in securely, so I'm not sure what it could be.
    Any ideas?
    Happened to me as well. Turned out to be the white ribbon that connected the board to the screen. I would make sure you did not hit the input button and check the connections.
      I have an FA-801 so it's a bit different under the hood. Below is a picture of the ribbon I'm dealing with, the left side looks a bit warped compared to the right. I have removed and reinserted them to no avail. Any idea where I'd find a replacement like this?
