HUD must see!
  • HUD must see!
    What do you guys think of this? Not hard to setup, searched the whole web for this and didnt find it, so its my original idea
    http://www.youtube.com/watch?v=Tf9mg...e_gdata_player
    Hope you enjoy and like!
    So the setup, found an old 7" lcd of camera surveillance and noticed it had a button to revert/flip/mirror the image. Hooked up my iphone, installed displayout app. Video in lcd, audio out to the car radio.
    Unfortunatly it doesnt work in daylight (yet).
    My goal was to flip the TomTom app, there are lots of apps in HUD mode for gps-based speed but I wanted navigation.
    Next step is to make it work during daylight (maybe with a sort of film on the windshield) and in combination of the new iPhone 4s Siri app that uses a very advanced voice control feature.
    Here is a Demo
    http://www.youtube.com/watch?v=nZSkvwpBBok&feature=youtube_gdata_player
    I tried to watch the video but got motion sickness and that music is another story. Maybe next time. SNO
      so...? do tell the details?
      How's it set up?
      How's it during the day time?
        Hm, looks like a pico-projector of an iPhone/iPodtouch inverted then pu ton the window/reflective film. If I ignore the music then it has potential, but how does it look from outside the car? would it be considered a distraction to other drivers?
          Interesting. Details?
            Alexp3,......I'm also a bit intrigued/curious on how you pulled this off too. Looks cool.
            Better with earplugs though.
              i am also curious of the details, though i suspect a simpler method-- i can see a double reflection on the window glass, meaning that he is probably projecting the image on non-modded glass, and i haven't seen too much positive info on using projectors due to the fact that they 'beam' more then reflect off surfaces, so i suspect it is a 7" screen placed flat on the dash..
              next project? subaru brz
              carpc undecided
                It is very similar to the reflection I get on my windscreen from my normal Lilli 7". The way mine sits in the dash it is tilted back slightly, so I get a fairly clear reflection on the windscreen at night, however it is in reverse (as you would expect!).
                So this does look similar, although having the image corrected to be right way round is interesting.
                  I'm guessing these "reflection of LCD on windshield" type HUDs only work at night? the results can't be close to oem HUDs that come in cars like BMWs. can they?
                    Is that a Jeep Grand Cherokee? How did you project the image on the windshield? Using portable projector or LCD? I'm also doing some modification on my Jeep WJ, try to find a way get the image via iphone. Could you provide more info about your project?
                      Yes its a jeep wj, howto is described in first post what did you modify?
                        So far, I integrate my iPhone via an adapter, so I can control the music by steering wheel and bought a Lilliput 7" screen . I'm thinking about how to mount it on the dash.
                        The HUD approach is fancy, but I choose to display the image on the LCD directly (non-reflection) before we figure out how to use HUD in daylight.
                        BTW: Try to use the portable projector instead of LCD.
                          To project on glass you will need a special film such as 3M Vuikiti (expensive) but for best result you will need a laserprojector, such as Aaxa L1\L2 also not realy cheap.
                          You can try something like this.
                          Or this
                            Some pics of my headlights
                              have any more detailed photos of that ipad install? What mount did you use?
