tm-701 installs
  • tm-701 installs
    A lot of people in here talk about the 701 and how it's working, but i've seen very few pics of it in action and installed. for those who have this unit could you please post a few pics for the rest of us.
    thanks
    2006 Nissan 350Z 6MT
    M10000; 120GB 7200RPM HDD
    512 DDR; 7" Touchscreen LCD; CoPilot
      mind if i ask how you currently have it installed by that i mean is it currently above or below? i see pics with it each way, for a minute i couldn't figure out what was wrong then i realized it was positioned in 2 different places. also which way do you like it better?
      thanks for the pics.
        http://forums.vwvortex.com/zerothread?id=823830
        here is my setup, pictures off the posting on my Volkswagen forum.
        Mine needs to be updated.
          Initially I had it installed below my headunit but I find it hard to shift so I relocated it on top of my headunit. It's much better this way because I can shift between gears freely. The only drawback now is that it's covering my climate control when it's open but it's no biggie though
            Pics of my install.....
            http://www.bankingdom.com/carputer/carputer.html
            [IMG]http://www.bankingdom.com/carputer/IMG_0860.jpg[IMG]
            got a video on there too
            My carputer
              Check here
              http://www.mp3car.com/vbulletin/show...6&page=1&pp=15
              Epia M9000, lili 7" vga&touch & 2xTM-7002S compo, camera with reversed image, 2.5" 60 GB, 256Mb DDR, Opus 90W, GPS usb... AND MEDIACRUISER of course!
                You can also look here
                http://digitalww.com/customer_installs.htm
                More info here----> http://www.gijsje.net
                  website is back up:
                  My carputer
                    So I take it that you guys use powerstrip to get the resolution just right so that it takes up the whole screen? Darn, I got alot of tweakign on mine to do.
                      And mine... Link on my sig...
                      Terran
                      My Project Site
                        Well I guess i'll make this my first post
                        My Sounddomain.com site
                          Bwahahahahah
                          I to have aprelude just no AC I wish
                          Originally posted by jspeeder9
                          Lilliput 8", C134 EPIA-M 900 (Black), A1-ITX, 256 Mb RAM, 40 Gb HDD, DVD, 802.11g, mini keyboard
                            Apologies for the relicant images, BTW how did you combine the PC and head unit into the AMP circuit?
                            I want a standard JVC or Sony head unit to go through the same amp as the PC and I don't want the PC to blow the head unit or visa versa, Also I want to place the pop out screen below the head unit except that there is a large cable tie on top of the digitalww pop out screen that is 5 mm high that does not make for a good fit for another DIn ontop so my pop out screen takes the top slot.
                            also the din holes were 2 small so I had to file the holes bigger. Any comments welcomed.
