Lilliput 809GL does not like my backup camera
  • Lilliput 809GL does not like my backup camera
    Ok I have done research to death on this topic and would loves some advice as I cant find anything that has helped. I have a Lilliput 809GL-80NP/C/T display and it works great when connected to my carpc, but when I plug in a backup camera it comes on for 1 second and flickers then goes black, the screen then times out ant auto powers off. i have tried all available inputs, IE: yellow and Red inputs, disconnecting all inputs except for the camera, Checked the voltage of both the monitor and camera, tried different power sources. This is the second backup camera I have tried, (the last one was a different brand) and had the same results. I have confirmed the cameras work on a television and the monitor as I said works fine with my carpc. Please help!
    are you trying this by enabling the reverse wire, or by manually switching to the camera input?
    next project? subaru brz
    carpc undecided
      I have tried it hooked up to my amp, brake light, and my cig lighter. All three reporting 13.24V clean with a +2 flux when accelerating, well within the cameras tolerance. If it helps, this is the camera I just got...
      http://store.mp3car.com/Infrared_Wat..._p/com-129.htm
      Is it possible that the Lili just cant handle the camera?
        that doesn't answer my question though
        you already said that you verified the camera works, with different 2 cameras, and you also connected them to a standard TV--that rules out a defective camera. you then said that you tried multiple points for voltage-- so that partially rules out the car being a issue(there could be something else on this side, but that would become more evident later on).
        so to try to reword my question-- have you tried manually changing the lilliput to the AV2 input, and getting it to display the image?
        there are still 2 variables that need to be worked out:
        first- if the video input works at all--hence the first question. another way to test this is to try a different non-camera device, like a dvd player, or portable video player.
        second, if the reverse trigger wire works. this is why i asked that the input be switched manually-- it eliminates the automatic triggering, that could be the original problem..
        carpc undecided
          Sorry I didn't fully understand. Lol. I tried running the camera from the yellow and red inputs, and yes I have tried manually switching. I have not however verified another device through the inputs. I will try that. I am also going to post a vid of what it does to (I hope) clear up any other questions. I also ran the cam off the psu on my carpc, and verified a clean 12.1v off it with my meter with zero flux from acceleration or accessories running. So, I feel pretty good about it not being a power source issue, but I am not going to rule anything out yet...
