Lilliput EBY701 Issue - Reverse Y
  • Lilliput EBY701 Issue - Reverse Y
    I have an EBY701 which arrived working great. Last time I worked on the enclosure it was necessary to separate the ribbon connector between the board and screen. I was very careful not to crease or bend anything. Now that it is back together the Y axis (only) is inverted.
    I have tried to reseat the ribbon a few times. It is snug in the connector and always returns the same results. Screen looks great apart from the Y axis being inverted.
    Is there a setting to correct this?
    Could it be the cable is broken (if so, where to get a replacement)?
    I forgot to add that I also put on a screen protection film.
      have you checked your video card output on your pc? some graphics chipsets have hot-key's for screen rotation's, so it could have been done inadvertently(i have done it more then a couple of times with intel integrated chipsets)..
      next project? subaru brz
      carpc undecided
        I just fixed it.
        Although I disconnected the ribbon at the PCB end. It was the connection at the other end that was bad. With a little bending and adjusting the screen flipped back to ok. I also managed to get the screen reinstated in the box without any problem.
        I recommend that you do not remove the ribbon cable EVER!
