Open frame usb touchscreen
  • Open frame usb touchscreen
    I'm looking at the pics of the open frame touchscreen 7inch monitor, model MON-120. How is the USB connected? All I see is connectors for the VGA and power. Can I extend the panel(the portion with the buttons) cables?
    the link is for a pandigital lcd picture frame, not for a vga-compatible monitor-- perhaps the wrong link?
    next project? subaru brz
    carpc undecided
      Sorry, don't know exactly what you are talking about. I don't see any link that I put, but this is it:
      http://store.mp3car.com/Lilliput_7_S..._p/mon-120.htm
      thanks.
        No, that's not a VGA cable. The connector you see is the SKS breakout cable connector that Lilliput uses. That breakout cable looks like this:
        http://www.mo-co-so.com/Replacement-...cs-lil-sks.htm
        The cable that runs from your PC to the monitor looks like this:
        http://www.mo-co-so.com/Replacement-...cs-lil-vga.htm
        1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
          Thanks, that messes my whole plan up. I was hoping to put a right angle connector on the monitor. With that connector my monitor wont fit where I need it to.
            You can trim back the connector and fit it into a tight spot. I removed three of the rubber rings and it fits very well.
              I thought about that, I was more concerned with if the hard plastic portion extended beyond the frame. If the hard plastic fell short about 5-10mm before the edge of the frame, then cutting back the rings would make sense for me. Or if it was safe to cut back the hard plastic.
