Seeking Decent Single Din Flip Up Touchscreen. Pics inside.
  • Seeking Decent Single Din Flip Up Touchscreen. Pics inside.
    Title says it. Due to the limited amount of room I have I'm faced with the choice to find a decent single din flip up touchscreen or hack my leather dash to pieces to try to adapt a double din monitor. I'm not sure if the latter would even work and it could possibly serve as a obstruction to my view of the road so I am not keen on taking this route. Please help me find a decent flip up.
    Through my research I've come to realize that flip up touchscreens are notorious for reliability and performance problems. Most of the reviews I've read on this site and others are quite old, I don't know how far flip ups have come since then.
    I will post what I've been able to find so far, a list of the flip ups I have heard of with pics, specs and comments made other members/customer reviews. Please feel free to contribute your knowledge, stories/experiences and suggestions to other flip ups not already mentioned. Thanks. BTW as you may have already noticed by my post count, I'm new so I apologize in advance for my screw ups.
    SP-716, DWW-700M, MTS12000 and TST-70NP/C
    (Yes these are all different names for this monitor)
    Motorized 7 inch touchscreen, 800x600, 800x480 native. Has VGA and composite input. I don't have any other technical specs.
    Big thread here: http://www.mp3car.com/lcd-display/56...0-and-etc.html
    Is motorized. Motors are weak and struggle when on a hill or when the car is accelerating. Can get to the point where the motors just give up. In one case site member said his unit failed on the 5th use. LEDs are bright so they are easy to see but perhaps too bright. One site member said he needed to cover up the LEDs with electrical tape in order to see at night. TV tuner does not perform well. Many members have had trouble getting video or the touchscreen to work with their computers. Touchscreen drivers have been described by other members as a "nightmare." Screen is easy to read in sunlight. Screen is too bright at night even when settings are dimmed. Screen needs to rest on something behind it in order to be stable, otherwise it tends to flop around. Onscreen video failure is not uncommon. Remote has a cheap appearance. Unit is big and requires quite a bit of room behind it in the dash.
    I don't even know if these are still available or where I would get one of these units. Last I heard the price ranged from $250-$400
    MTSVO-SC, also known as k301
    Fully motorized 7 inch touchscreen. VGA input.
    Screen size: 7 inches, diagonal (16:9)
    7-inch digital TFT LCD (new panel)
    LCD brightness (cd/m2): 400
    Resolution (pixel): 800 RGB x 400
    Dot resolution: 2,400 x 480 = 1,152,000 (dots)
    Supported resolution: 640 x 480 - 1,600 x 1,200
    Master dimensions (W x D x H): 178 x 155 x 50mm
    Touch screen interface: USB port (RS232 optional)
    Operating voltage: 10.5 to 14V DC
    For in-car PC, DVD player, GPS, and various VGA applications
    In-dash type, fully motorized TFT LCD
    Contrast ratio: 300:1
    Diagonal size 16:9 and 4:3 adjustable
    4-wire resistive touch screen panel (USB)
    Multi-monitor touch screen support
    VGA input (15-pin D-sub)
    USB interface
    Video input system: NTSC/PAL/SECAM auto switching
    Three RCA video inputs
    Upgraded high-brightness CCFL
    Touchcreen has to be recalibrated often. Difficult to see in sunlight. I don't have much more info then that from peoples experiences.
    This screen is no longer available on mp3car.com, I don't know why. I don't know where else one of these could be found. mp3car.com store had these priced at $450. Used ones can be found for $130.
    Lilliput GL701-NP/C/T
    Motorized 7″ 16:9 Wide Screen In-Dash Touchscreen Monitor.
    resolution:800x480, displays up to 1024x768;
    VGA interface
    AV input / output;
    FM/AM radio;
    TV function (optional);
    4*45W audio power amplifier output;
    Rearview mirror function;
    Built-in multi-language OSD;
    Remote control
    Display Screen: 7 inch TFT LCD
    Resolution: 800 480 (1,152,000) pixels
    Color System: PAL-4.43 NTSC-3.58
    Ratio Aspect: 16:9
    Contras Ratio: 500:1
    Brightness: 300cd/m2
    Viewing Angle: 50/70(U/D),70/70(L/R)
    Audio Output: ≥100mW
    Input Voltage: DC 11-13V
    Power Consumption: ≤10W
    Dimension(mm): 179L 49W 190H
    Weight: 1635g
    Many of the old reviews say the motors and gears are very prone to failure. However I've also heard that Lilliput recently updated this model and now uses metal gears. Can anyone confirm this? Has anyone had any experience with the more recent run of these monitors?
    These are priced for around $360.
    XENARC MDT-X7000
    Fully motorized screen with Tilt adjustment
    Built-in 55w x 4 amplifier
    Built-in CD, video DVD player
    Built in DVD decoder with Dolby Digital 5.1
    USB DVD-ROM in PC mode
    Built-in AM/FM Radio Tuner
    5-wire resistive Touch Screen (USB)
    Multi-Monitor Touchscreen Support
    DVI Input x 1 / VGA Input x 1, AV Input x 2
    PC Audio input x 1, AV Output x 1
    Built-in 2 port Front Access USB hub
    Multi-function remote w/ PC media playback control
    Front panel PC Power switch control
    On Screen Display Control via Touchscreen
    NTSC / PAL Multi-System
    16x9 Aspect Ratio
    High Resolution Display
    Night time backlight dimmer for night-time use
    High Performance Video and VGA Processor
    High Quality Scaling & Anti-Aliasing
    Automatic display adjustment
    Anti Glare Coating
    Model #: MDT-X7000
    Screen Size: Diagonal 7" (16:9)
    Physical Resolution: 800 (H) x 480 (V) WVGA
    Supported Resolution: 640 x 480 ~ 1024x768
    Dot Resolution: 2400 x 480 = 1,152,000 (dots)
    LCD Brightness: 400 cd/m
    Touch Screen Interface: USB port
    Operating Voltage Range: DC 10V ~ 16V
    Power Consumption: 120W
    Operating Temperature: 41F~131F (5C~55C)
    Storage Temperature: -22F~185F
    Dimension: 1-DIN: 7" (W) x 2" (H)
    Weight (lb): 3.97
    FCC, CE, E13 Certification
    This monitor is tilt adjustable but not side to side angle adjustable. One site member said it is nicely visible in the daylight. Touchscreen works nicely. Wiring is a pain in the but because there are so many wire coming from the back of the unit. Has a VGA and a DVI input. Has a DVD drive that can play DVDs on screen and/or function as a DVD drive for a carputer. Firmware issues are prominent. There supposedly are two generations of this monitor. I don't know what the difference between each is or when the new generation was released.
    This unit is no longer available on Xenarc direct. I don't know where I could find one. It was priced around $700 new.
    Xenarc 700IDT
    Spring loaded, automated mechanical flip-out design (Non-Motorized)
    Left and Right swivel
    VGA Input x 1 & Video Input x 2
    16x9 Aspect Ratio
    High Resolution Display - up to 1600 x 1200
    Auto detects 800x480 resolution
    Upgraded High-Brightness CCFL
    Adjustable backlight level for night-time use
    Pixelworks High Performance Image and Video Signal Processor
    AISS - Advanced Image-Scaling and Shaping
    Auto power-on upon signal detection
    20-Pin heavy-duty connector
    Has an anti glare coating
    Supports 11V DC ~ 24V DC
    Supported Resolution: 640 x 480 ~ 1600 x 1200
    LCD Brightness: 500 cd/m
    Contrast Ratio: 400:1
    Operating Voltage Range: DC 11V ~ 24V, 1A
    Power Supply: DC 12V
    Power Consumption: <8W
    Operating Temperature: 23F ~ 158F
    Weight (lb): 4.20
    Has a 24 Month Warranty
    12V DC cigarette lighter car adaptor
    12V DC connection cable
    Touchscreen drivers for DOS, Windows, Linux, and Mac OS
    I suppose that the fact that these are still available from Xenarc is a good sign. There are two generations of these. I don't know what the difference is between them internally. I have seen two different styles of this monitor as shown below. I believe that these differences in appearance are due to the difference in generation. Would anyone be able to confirm this? Does anyone know which one is the newer one? Does anyone know what the differences are between both?
    Even though this unit does not have a built in DVD drive it is possible to add one. I've found a useful how to thread here: http://www.mp3car.com/the-faq-empori...rc-700idt.html
    This is not a motorized monitor, it is a spring loaded manual flip up. Less coolness factor but more reliability due to the fact that there are no motors or gears present to wear out. Video performance is good, wiring is easy to work with, touchscreen is accurate. Other members have mentioned there is a high brightness model available but the Xenarc site makes no mention of this. Some say the visibility is poor in sunlight. Multiple people have described the spring loaded opening action as quick and violent and that it could strike a person or object in the way. One member said the ribbon cable was problematic. Driver issues are prominent. Does not have vertical tilt capability. Monitor may rattle with road bumps.
    These can be found for $150 new.
    I don't know if the SP-716, MTSVO-SC or Lilliput GL701 are up-down tilt adjustable. Does anyone know?
    Most of the member/customer reviews I've summarized were from years ago, some from as far back as 2004. Some of it may be out of date. If you notice this please post.
    Again if you know of other options please feel free to share. Please help me to choose, thanks.
    My guess is that most of these screens are discontinued. My guess is that most Car PC hobbyists just rather mod and install a double din setup. Originally I had one of these screens, the K90, but it didnt like OEM, it actually looked odd. Once I modded my dash with double din, it looked so much better then a motorized screen.
    For a new project I am once again looking into flip up screens. I specifically want one that is not motorized because I do not want to worry about the motor. The only one I see that is still being sold is the Xenarc 700m I think it is?
    Where are you finding the screen for 150? Because I need two of them for my project!
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
      Wow you need two of them?
      The ones I saw for $150 were being sold on ebay. Both are gone now but others can be found for fairly cheap.
      I've never heard of the k90. I understand you didn't like the look but how did it perform? Got pics?
        Well, because it was so hard to find them, I decided to change my install. The passenger will get a double din style screen. They do not really need to see the road, well not like I do. My side though can not have a double din because I cant see the road. So I want to use the motorized screen to fold in when I drive. Then when I park, the screen comes out.
        I want to share a link with you! Found this on Ebay. Only two of them left and these are priced horriably low, which is good for you! Its almost less then half price!!!!!!
        4X MK808b
        3x Perixx Touchpads
        3x 7 inch Screens
        1x Win 7 PC
          The K90 is the previous screen that came before the K301. It suffured from the same issues, but mine only did it when the A/C was on. The screen sat inbetween the A/C vents. Had no other issues.
          4X MK808b
          3x Perixx Touchpads
          3x 7 inch Screens
          1x Win 7 PC
            I don't know what's going on with ebay links, but they keep converting to rover.ebay.com. Can you post your ebay link again, maybe inside a code wrapper or something?
            1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
              My link is using the wrapper. Just ignore the stupid Ebay link that skimwords is putting in the post. Mine is all the way at the bottom of the post. This skimword $h!+ is annoying.
              4X MK808b
              3x Perixx Touchpads
              3x 7 inch Screens
              1x Win 7 PC
                ^ tell me about it..
                the other day, i thought i had a virus causing the links, then i thought a person was manually adding linked garbage, and almost called them out on it and reported the post..
                next project? subaru brz
                carpc undecided
                  It seems like its a feature MP3car added! I notice they are slowly adding advertisement to the forums, just not as much as when your not a member.
                  By the way, the one I linked to is non-motorized. So I think the way it works is that you push and the screen pops out via being spring loaded.
                  4X MK808b
                  3x Perixx Touchpads
                  3x 7 inch Screens
                  1x Win 7 PC
                    Some "feature". I had to quickly copy the link and paste it into notepad. Otherwise it automatically turns into a rover link. For anyone else having issues with this stupid feature, the ebay item number is 270865146103.
                      Thank you HiJackZX1 for sharing the link. That's the same buyer I saw before selling them very cheap.
                      As I mentioned in the first post there seem to be 2 different styles of the Xenarc 700IDT. I believe one is the older generation and the other is newer. Can anyone else confirm this? Does anyone know which one is the newer one?
                      The one in the link provided by HiJackZX1 which looks like this:
                      And one that looks like this:
                      Note the difference in button shape, location and color and the difference in the shape of the frame.
                        i just keep reminding myself that they need to generate revenue somehow, and ad's seem to part of a growing forum's income...
                        it's hard to complain when the forum doesn't cost me anything to be part of...
                        carpc undecided
                          I don't mind them generating revenue. By all means, if they can earn a few pennies if I click on a link to an eBay page, go for it. I do mind when whatever was done kills the links, however. Hopefully it's just a simple configuration problem they can fix.
                            Gave Xenarc a call today. Seems that the one with the blue buttons is the newer generation 700IDT. They also said that the drivers issues of the past are not a problem anymore, especially if you run windows 7.
                            Since so many of these monitors are not available its pretty much a decision between the Lilliput and the 700IDT. The Lilliput would not allow me to run a built in DVD drive, the 700IDT would. The 700IDT also costs a hell of a lot less than the Lilliput. So I've decided on the 700IDT, I'm going to go ahead and order one.
                              The first gen is the one with the silver buttons. Second gen is the blue ones. Gen 1 screen suffered from touchscreen failure and something else. I hear the second one was built better, but sometimes the touchscreen was iffy. It seems that all these type of screen, no matter the brand, suffer from touch screen issues. My guess is because the constant movement destroys something?
                              4X MK808b
                              3x Perixx Touchpads
                              3x 7 inch Screens
                              1x Win 7 PC
