group buy on Sharp LQ104S1DG21 ...
  • group buy on Sharp LQ104S1DG21 ...
    I could get 10 of these for $75 a piece, would anyone want to get one? They are 350 nit and SVGA 800x600 res.
    Here is the datasheet...dataheet
    Aopen i855GMEm-LFS with Dothan 1.8ghz
    512mb DDR333
    Windows XPpro SP2
    Does this model accept the the Datalux M1023 controller card? And whats the viewing angle? I only skimmed over the datasheet and did not find it.
    If so count me in. If not NM.
    edit: Also do they include the backlight?
    What im curently listening to.
    My complete carpc setup
      Hmmm. I assume they include the ccfls because it says 350 nits on the order site. I too have the datalux controller. This lcd has a 41 pin hirose connection, but looking at the datasheet, it has the exact same pins, just a few extra ground pins (10 extra to be precise). If anyone knows more than I do, please post!
      512mb DDR333
      Windows XPpro SP2
        I just compared the pinouts from my datalux LG panel and it is the same, there are just more ground pins that would have to be connected, thus a custom cable would be needed. Also, the datasheet says the ccfls are included, but no inverter.
        512mb DDR333
        Windows XPpro SP2
          I got an inverter for my LQ104V1DG11 from these guys...works, great.
          Here's the link for the dimming inverter or the LQ104S1DG21: http://www.milesie.co.uk/asp/product...?ProductID=355
          Keep in mind the pricing on their page is in pounds...should be 45 pounds (74.09 dollars...ouch) total (including shipping) to the USA (that was the price it gives me any way..)
          That's the only place I know to get this inverter...any one else want to post other places to get the inverter for this?
          It'd be nice to upgrade my 640x480 screen to 800x600 but I think that the controller I have (allenruble's datalux controller) is only 640x480 since it uses the 31-pin hirose not the 41-pin...oh well, about to check...but if not, hopefully this info will help the group buy.
          1999 Plymouth Voyager (That's right, big-pimpin' in a minivan.)
          PC built into console
          worklog with pics: http://www.mp3car.com/vbulletin/showthread.php?t=46359
          Some of my music: http://www.myspace.com/markquestion
            I, myself, am interested. But reading through this, I question the compatability issues you brought up. Correct me if I'm wrong, but as long as the Panel voltage is correct, and the color data bits match from controller to LCD, then it should work, right? As far as the extra grounds go, couldn't you just connect one ground from the controller to the LCD, and split of jumpers to the other grounds on the LCD? Ground is ground.
              hmm good questions, So we would need to build a custom cable, the controller cannot and will not just fit in, like the sharp lq10d367? ????? will it work with the controller mentioned? hmmm
                Good question about the controller resolution. I believe it's the timing that is the issue, not the color bit. If only Allen Ruble could tell us if it can support it....someone find out!!!!
                The ground (all of them) can be connected to frame ground, there is no worry about that.
                The inverter that fcc listed is for the LQ121S1DG31 not the lq104s1dg21. It may work, I don't have time to look into it, maybe fcc did....but the same inverter for the lq104v1dg11 should work, it's the same nits. There are some places in the US that sell them for $50. I was about to order one, I'll post info later...
                512mb DDR333
                Windows XPpro SP2
                  I would be interested if/when the controller q's are answered
                    Or would you all rather have the Sharp lq104v7ds01? It is a 640x480 Transflective display. Beautiful for daylight apps but it has a narrower viewing angle. I could get ten of these for roughly $93 a piece. It is a 31 pin hirose and would accept the datalux controller directly.
                    http://www.sharpsma.com/pub/productf...q104v7ds01.pdf
                    512mb DDR333
                    Windows XPpro SP2
                      not narrower. I just upgraded from a narrow view screen. Narrow view sux. Ide rather go with wider. I was insterested in this screen cause of its nits level.
