Separate touch panel from LCD - Lilliput EBY701
  • Separate touch panel from LCD - Lilliput EBY701
    Can anyone quickly outline how to separate the assemblies? I would like to replace the LCD itself, or mask the dead pixels on the side of the screen without interferring with the touch panel.
    EBY701 in Bybyte enclosure. I can easily take the boards off, but haven't dared disassembling the LCD/touch assembly.
    Thanks,
    Z
    2002 Maxima SE 6-Speed
    Shuttle K45 + Core2Duo / OPUS 150 / Lilliput 701 + BYBYTE casing / Factory BOSE integration
    http://www.cardomain.com/ride/2285382
    The touch panel is attached with a thin DS tape. If you have a steady hand, you can separate the touch panel using a thin razor blade and gently (read very gently) slice the tape.
    Make sure you do not insert the blade past the metal bezel of the LCD. This will help ensure you don't scratch the LCD.
