Can I use this laptop display?
  • Can I use this laptop display?
    Going through some old parts in a closet and found a couple of A1181089A Sony Laptop displays. I think these where going to be used to replace a few damaged laptops at one time, but never got used so they are just sitting new in the box.
    Could they be used as a secondary display for the center of a truck if I picked up some housing?
    Here are the specs:
    Specifications:
    Model Sony A1181089A Laptop LCD Screen
    Size 13.3" WideScreen
    Length x Height 11.3" x 7.1"
    Resolution WXGA(1280 x 800)
    Backlight Lamp LED
    Video Signal Connector 30 pin Video Connector
    Technology Active Matrix TFT
    Screen Surface Glossy
    Product Type Laptop LCD Screen Display
    Condition New Grade A+
    Usually laptop displays connect to the motherboard via an LVDS connector. If you are planning to hook up this secondary display to a VGA, DVI or HDMI port, you'll run into problems. Unfortunately, hooking up an LVDS display is more trouble than it's worth. It might be more cost-effective to just buy a new LED monitor.
    My Project: All-in-one Double Din Unit
      Ok thanks for the tips. I'll just toss it and pick up a regular old monitor.
