twin headrest monitor + dvd Headunit
  • twin headrest monitor + dvd Headunit
    I tried a search but to be honest had no idea what to search under
    I would like advice on what i need to achieve the following
    I have 2 Eonon (cheapo) Headrest DVD Monitors and a Pioneer AVH-P350BT headunit
    I would like to be able to...
    Connect both headrest monitors to headunit (only 1 output on pioneer)
    Connect both headrest monitors together. (1 in and 1 out on monitors)
    That way i can put a dvd/ipod video on AVH and send to both rear monitors, or put a dvd in either monitor and play on both monitors.
    Is ther a product available that i can use as an auto switching video distrubtion box or something???
    I guess i need to be able to auto switch from 3 inputs to 2 outputs.
    im not sure if you have resolved this but:
    try buying
    *just video: ONE RCA SPLITTER CABLE
    * Audio and video: three RCA splitter cables off ebay
    most units give out enough of a picture voltage for two screens... otherwise you may need a dedicated video amplifier/splitter...
    http://www.ebay.co.uk/itm/RCA-Audio-...item3f0a0f7c3a
    (this one requires "more room" behind the unit... but what i would do is split it at the first headrest and take it across to the second headrest...)
    if you splitting behind the unit though, go for this: http://www.ebay.co.uk/itm/RCA-PHONO-...item4cfe169ed0
    --- if picture signal is too weak install one of these ;
    http://www.ebay.co.uk/itm/Video-Sign...item4845477b33
    NOTE: THESE ARE NOT THE CHEAPEST LINKS, JUST THE FIRST ONES THAT CAME UP! SEARCH EBAY AND THERE ARE CHEAPER ONES...
    [DVD UNIT] ==RCA WIRE========================= SPLITER (1) ==PASSENGER SEAT===
    (2) ======================= DRIVER SEAT=====
