Lilliput 629/619 - Windows 8 Touch Screen Driver Problems.
  • Lilliput 629/619 - Windows 8 Touch Screen Driver Problems.
    Hello everyone. I recently receiving a Lilliput 629 from mp3car.com with the intention of using it in my car PC with the recently released Windows 8. When I just plug in the screen, without installing the TouchKit drivers, the touch and 'gesture' features work; however, the X and Y axis are switched making it unusable. When I install the TouchKit drivers the digitizer is no longer detected as a touch and pen interface but a mouse. This make the touch and gesture features not usable which I need to use Windows 8 as my primary interface. Any help is appreciated.
    PC Specs:
    Lilliput 629/619/701 (All the same)
    ASRock AMD APU 250
    4GB DDR3
    120GB SSD
    If there was a program that would just "rotate" my touch input or switch the X and Y axis I would be set. Thanks in advance I've been looking everywhere but to no avail.
    Did you ever figure this out? I just migrated to Windows 8 from XP and I'm having the same issue.
      Well dang I am looking at getting a Lilliput for a project but I might go different than windows 8 if this is still an issue
      Sent from my Galaxy Nexus using Tapatalk 2
        This whole thread is good, post #94 has drivers
        http://www.eightforums.com/tablet-to...-mouse-10.html
        I've got my 669gl working great with Win8 x86
          It works but my x and y axis are wrong. Is there a way to switch these? I tried these drivers but the install tool says it is for vista and xp only. I tried to install through device manager but it says it wont work on x64 bit.
            It installed with no problem on my system. Fixed my X-Y axis problem.
              Could you possible walk me through the install with filenames? I'd really appreciate it, thanks!
                Yah. I'll have to hook everything back up, I don't remember it being anything special.
