change AV when i do reverse
  • change AV when i do reverse
    I have CTF400-ML and this monitor don't have automatic system for rear cam (wire to connect 12v).
    And I need to change the AV1 when i do reverse.
    I could connect the monitor micro-switch (to change AV) to the relay, but would not work because if the trigger on relay stay connect more 1 second, the monitor turns off.
    I need a solution that the micro-switch turns on only 1 second, when I have the 12v.
    there are timer relays you can use, called TON or TOFF.
    another cheap solution, connect a serial capasitor to the relay if you want it to be energised for a short while when power is applied.
    or connect a capacitor in paralel with the relay if you want it to release later after power is disconnected.
    Zotac Zbox id80
    64Gb Sansdisk SSD
    4Gb Ram, BU-353-S4 Gps
    7" resistive touch screen
    Win7 x86, BS 10.0.470, RR, Reborn,
    KKCanBus, BT Mobilephone, igo8.3, Garmin
      how good are you with circuits? you could use a 555timer wired up in monostable operation:
      http://freespace.virgin.net/matt.wai...y/pinouts/555/
      next project? subaru brz
      carpc undecided
        I managed to do with 2 relays and 1 capacitor. The 2nd relay coil is supplied with capacitor, and only stays on about 1 second.
        Tks
