Recommendations on a $100-$200 lcd
  • Recommendations on a $100-$200 lcd
    Im looking for an lcd that is between 6.5"-9" and can be used for reading text and is daylight viewable. Any comments or recmendations would be greatly appreciated!
    Re: Recommendations on a $100-$200 lcd
    Originally posted by davidh
    Im looking for an lcd that is between 6.5"-9" and can be used for reading text and is daylight viewable. Any comments or recommendations would be greatly appreciated!
    Welcome to the forums!
    First thing you should learn is a search button (top - right corner), it is your best friend.
    From your requirements it sounds like you need a 7" VGA LCD (xenarc) but it is about twice your budget at $400. You will have to add some $ or look into a composite LCD monitor.
    Brightness - has to be at least 250 nits to be daylight viewable.
    Text - what text are you planning on reading? There are several different ways to go around this issue:
    1. Get a VGA LCD
    2. Increase font size in windows (composite LCD)
    3. Use an interface like MediaEngine
    4. If you really need to read a lot - wait till you get home
    Do a search on these LCDs and decide for yourself:
    7 TM-701L
    7 TM-7002S
    7 GA700YYV or DS700YYV or 700TSV
    Additional search topics:
    VGA LCD
    Composite LCD
    Media Engine
    This should last you a couple of days and give you a lot of ideas.
    Armen
    http://www.digitalww.com
      Im planning on running WinXP, i want something that i am going to be able to read file names with. I have searched the forum, but i thought id repost to have any new hardware or new people add there opinion. The monitors you suggested look really cool, but im looking for something a little cheaper... Thanks!
