Power Lilliput monitor with usb
  • Power Lilliput monitor with usb
    I had a carpc install and have since switched to a tablet install, but i do have this Lilliput monitor left over. I would like to mount this inside of a computer case i have and was wondering if there was a way i could take the existing power cable for the monitor and solder it to a usb cable for power?
    If not is there a way to do it on one of the 12 volt rails?
    I was looking through the forums and could find anything on powering one with usb.
    any help is much appreciated
    Never accept STOCK equipment.
    Can't from USB, as USB can only provide 5v.
    Tap into a HDD molex for 12v.
    How about the Wiki?
      or you can connect it to plain-ole automotive power off the main battery to get it to work.
      next project? subaru brz
      carpc undecided
        If you are mounting it in the computer case, tap the 12v rail of your computer power supply.
