HD Monitors for Android board?
  • HD Monitors for Android board?
    So I'm pretty set on running a Hardkernel O-Droid X2 or U2 as my CarPC, but the main issue I'm running into is display. It only puts out HDMI, and because it doesn't adhere to the VESA standard, you can't convert it. I've searched high and low for roof monitors that support 720P or 1080P over HDMI, and had absolutely zero luck. Any advice?
    Check out http://mcpia.com/MT_S070_01A.html
    I just got it along with an O-Droid X2 for a carputer build. It works great and has a proper non-sucky capacitive touch screen. Biggest problem I have with it is it has way, way too much bezel and no easy way to remove it, it appears. I want to mount mine in an OEM nav bezel for my E39 but there is so much bezel on the screen I don't think it will ever come close to fitting. :/
