screen flicker
  • screen flicker
    anyone know the cause/solution to fix a flickering screen when you turn the volume up. ? i have a intel D510M0 board hooked up to a four channel AMP. when i turn the volume up the lilliput screen kinda flickers... like lines appear. i dont know how to describe it. a video might be better......the screen is powered by the PC power supply.
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Bad connection - unplug & replug video and power cables.
    Bad GND - check GND connections and screws etc.
    Shared noise or insufficient wire gauge if sharing the same +12V distribution or GND wires, or if in close proximity (eg, amp power to video power or signal).
    After that it's flimsy screen construction (mechanical vibration) or maybe voltage dips/noise.
      thanks, i do have the CarPC sharing the same connections as the AMP. I will try to seperate the connections eventually. Its not bad but looks tacky when the music is playing loud.
      CarPc
      Project "Driver"
      Planning [99.9%]
