Quick disconnect monitor
  • Quick disconnect monitor
    I am looking to add a pc in my truck but am trying to make it not visible. I have a space on the top of my dash that I could put a monitor in but want to be able to remove the monitor quickly. Is there such a thing as like a dock or quick disconnect for the cables to do something like this?
    Thanks,
    Scott
    You may want to look into a pop out monitor that fits into a 1din opening. You can hide one of these in various places depending on the type of truck you have. You could even take the cover that folds down and glue something to it so when the monitor is folded in it is hard to tell it isn't a normal part of the truck. Otherwise your best bet is to hid it behind a panel that is removable. A removable panel could be done reasonably easily too. Just get an HDMI monitor and mount the bracket in your truck in a manner the screen is removable. Then you just hide the cables somewhere in the dash when not using it. Most monitors you can mount in your vehicle will have 12 volt plugs on them. Anything else won't be as easy to remove. Be aware that you may wear out the socket if you unplug and plug the plugs all the time. You may want to get extension cables for each that you leave plugged into your monitor so the cables can wear out where they connect together which is easy to replace. A worn out socket means you try replacing the socket or the monitor.
      Thanks for the info! Good tip on the extension cable. I was not even thinking of hdmi but having to connect and disconnect and VGA cable every time, hdmi would be much easier.
      Thanks,
      Scott
        i'd go with a wifi setup and a tablet if you want something easily removable. you may have one cable (power) but you probably wont always need it since there is a battery on board.
        i had a win7 tablet, belkin network usb hub that was hooked up to a usb ss hard drive and a usb dac (for audio). and it seems to meet all your goals.
        edit: here is the proof of concept: http://youtu.be/CUr1leHiZ58
        New System in progress:
        M10k
        Phaze TD1500 ~> Seas g18rnx/p
        Zapco Ref 500.1 ~ 12" tc-9
        Transflective Xenarc
        My Car Pc Install
        My Boat Pc worklog
