8.75" x 5.3" - Best display with these max dimensions?
  • 8.75" x 5.3" - Best display with these max dimensions?
    For an upcoming project, I play to spend a maximum of $300, preferring about $200 if possible.
    And my max dimensions are 8.75" x 5.3".
    It will be a custom fab install where I tear apart my SUV's center dash for it.
    What is a good touch screen in that price range?
    It will be for a PC running Android.
    I just need it to have:
    • HDMI input
    • auto-power on
    • RCA Video input for rear camera
    • auto brightness, or the ability to control brightness by external input.
    This is the best thing I could come up with on my own, but I'm new to this and not totally sure what to look for:
    • High Brightness Lilliput 869GL-80NP/C/T-HB 8" Touch Screen LCD Monitor DVI HDMI
    http://store.mp3car.com/High_Brightn..._p/mon-137.htm
    I'm guessing that panel is about 7.5" x 4.4" once removed from the housing. I found they usually add 6mm per side X and 5mm per side Y to the active screen dimensions. (viewable area)
      Yeah, the max dimensions include any sort of open bezel or "regular bezel".
      After tearing up dash, I get:
      W = 8.75" / 222.3mm
      H = 5.3 / 135mm
      I used a screen size calculator for a 16:9 type and got these numbers:
      10" Diagonal screen is 8.72 x 4.9
      9" Diagonal screen is 7.84 x 4.41
      So I'm thinking a 10" screen is out. But a 9" open bezel might fit.
        One other thing to remember is the brightness decreases with larger panel sizes. Here are the sizes (25.4mm per inch) I found when I was looking for an open frame screen in the 16:9-10 aspect:
        160.8 x 106.8 x 4.2 600:1 Contrast 400 Luminance 7" 1280 x 800
        192.8 x 116.9 x 6.4 600:1 Contrast 400 Luminance 8" 1024 x 600 ZJ080NA-08A 1024*600 CHIMEI INNOLUX May 2012
        192.8 x 116.9 x 6.4 500:1 Contrast 450 Luminance 8" 1024 x 600 HSD080IDW1-C 800*480 HannStar 2009 Dec 2009
        192.8 x 116.9 x 6.4 500:1 Contrast 450 Luminance 8" 1024 x 600 AT080TN64 800480 Innolux Mar 2010
        213.4 x 129.6 x 5.45 500:1 Contrast 180 Luminance 8.9" 1024 x 600
        211.1 x 126.5 x 5.9 400:1 Contrast 200 Luminance 9" 800 x 600
        210.6 x 166.6 x 5.8 400 Luminance 9.7" 1024 x 768 (a 4:3 aspect screen)
