Audi MMI Options
  • Audi MMI Options
    Hi,
    There seems to be a distinct lack of options where the MMI is concerned, and looking everywhere for any other installs (failed miserably).
    After some hard thinking the best I can come up with is this -
    * Video output - Supposedly on the back of the MMI screen there is an AUX video input, so I could connect the carpc to that for video.
    * Touchscreen Interface - So my idea was to buy touchscreen overlay kit, and mount it in front of the exist MMI screen. I would plan to remove the dashboard and then sandwich the overlay kit between the dash and MMI screen. This way everything will look stock and give me the a carpc and not hack the MMI to bits
    http://linitx.com/product/7-inch-tou...FUMUwwodh50A8A
    Click image for larger version
    Has anybody tried doing this before? can anybody spot an issues?
    Guy
    www.facebook.com/j666gak
    You will need a pc that outputs comp or s-video. Have you hooked up a PC to that aux in to see what kind of resolution you get. usually on video out via comp or s-video it looks terrible on a tv screen. Do you know what resolution that monitor has, it might be too low like 400x260. Just a thought Good luck SNO
      i know that this isn't the same unit but it might be helpfull....!
      Vw Sharan 2007 1.9tdi || Exide 100Ah
      Fuzzy 945gme + core duo T2400 + 2gb ddr 667 + pci nvidia 5500 256mb + kingston v300 60gb + hdd 2.5" 100gb 5400 + Sure Gps module
      Primary monitor 8" 800x600 || Secondary monitor 15.4" 1280x800
      Powered by M2 atx
