Carnetix 10.4 Touchscreen LCD Monitor ???
  • Carnetix 10.4 Touchscreen LCD Monitor ???
    Has anyone played with the Carnetix 10.4" Touchscreen LCD monitor ?
    http://store.mp3car.com/CarNetix_10_..._p/mon-169.htm
    I just installed one (late yesterday)...
    I think I will have a few questions in a day or two if I dont figure it all out on my own soon...
    I am having problems getting my PC to recognize the USB cable for the touch screen when I plug it in (Yes, I loaded the drivers I believe).
    I am also not quite sure about some of the settings... Does it remember things when power is removed and reapplied? I am not quite sure. I seem to have to push the power button on the back to get it to come back on after I power it down and repower it up... which is sort of a pain as it is not easily accessible in my installation.
    I only have an hour or so into this...maybe I will figure it all out in another hour or two.
    I haven't found anything online about these monitors... looking for someone else who has gotten one to work well or a pointer to some online resource other than the brief instruction manual.
    Rick
    Well, my major problem has been figured out...
    I sat in the parking lot after work for a couple of hours messing with things.
    The monitor comes with several cables... including HDMI to HDMI+USB, HDMI to DVI+ USB.
    I was using the HDMI to HDMI + USB cable. The much smaller HDMI connector takes up way less room than the DVI connector does.
    Running out of options, I used the HDMI to DVI cable (I have multiple video outputs on my PC). When I the USB connector in, Windows found it and the touchscreen driver came up. Life is good now.
    I emailed MP3.com to see if I can get a replacement cable however, as the HDMI cable is way easier to use in my installation.
    Now if I can figure out how to keep the monitor from shutting off every time I turn the power off I think I will be a happy guy.
    Rick
      DVI cable lasted four days before it developed a short...
      Frustrating
