View DVD & PC with VGA (640 x 480)???
  • View DVD & PC with VGA (640 x 480)???
    Is it possible to use a VGA (640 x 480) resolution to watch DVDs and connect to a regular PC, assuming the proper interface to the LCD???
    huh?
    I guess you can?
    What im curently listening to.
    My complete carpc setup
      Its not clear from your post...do you want to use a computer monitor to watch a DVD player? Or do you want to connect a DVD player to your computer?
      KG6OQD
      www.americansandassociation.org
        I want to be able to play DVDs in my car and i have a VGA 640x480 res LCD. I also want to be able to connect the same LCD to a pc and use it as the monitor.
          If it has a standard vga connector on it, it will work fine.
          Have you even tried to connect it?
          Remember you need a DVD player to be able to see DVD's on it.
            Never been connected. Dont have a DVD player yet. I was just wondering if The DVD format or output had a minimum resolution requirement to view them..
              some of the original players actually force the res down to 640 x 480. Come to think of it, Im almost certin windvd does this on my toshiba lap top (6 months old 1.8 g)
              Standard TV res is 720 x 480
              Gizmo-
              Techonlogy on Wheels
              http://www.hjnetworks.com/car
