7" screen, which mobo/gfx to buy for 16:9 TV out?
  • 7" screen, which mobo/gfx to buy for 16:9 TV out?
    I've ordered a TM-702L 7" screen from Digital WorldWide - I was going to buy a mini-ITX board to run it but have since found out that the mini-ITX can't run a 16:9 resolution (only 4:3) from the TV out port.
    Instead I'm looking at a VIA EPIA M9000 which can supposedly run a decent 16:9 resolution via the TV out?
    Any other boards (preferably small!) that will run the 7" screen via TV port at a 16:9 resolution?
    Or a PCI graphics card with TV out port that I can use in the mini-ITX board at 16:9 res. (Not VGA)
    I'd like to get this sussed before buying a board that doesn't do what I require of it!
    Thanks in advance.
    EDIT : All of this will be done on Win98SE by the way, I have spare 98se licence - I do not have a spare XP licence
    Will be used for MP3 primarily, GPS (probably "Directions" Infomap), full screen DIVX. Main concern at mo is getting one that does the 16:9 (Or near as dammit) in TV format!
    Nehemiah M10000 board, 512Mb RAM, Win98'lite', 7" TFT DIN in-dash VGA touchscreen. IR keyboard. GPS.
    First off, the M9000 and M10000 EPIA boards by VIA are all mini-itx form factor, that is, 72mmx72mm.
    Secondly, I don't think either of them can do 16:9; however, with the proper programs/tweaks, their video cards can be run at something similar to 16:9, you just need to figure it out and tweak it accordingly.
    Do a search for widescreen and windows xp, you'll find a lot of hits. I don't know about Win98, though....
      Thanks for the reply - I understand the boards don't give the outputs as 'standard' and am quite happy to use PowerStrip etc - but just incase anyone has been this route *with this screen*, I'd like to know what hardware people have had success with etc...
        my shuttle fv24 does 800x600 to the xenarc with no issues what so ever
        1997 Jeep Wrangler Rugged Waves
        Ebay Stuff For Sale
          Isn't that 1.3' - I'd rather have nearer 1.7' -
          Does your image look stretched? (That is what I am trying to avoid!)
            doesn't look stretched at all to me
            Ebay Stuff For Sale
              Just had a look at your pages, very nice - as you say - your image doesn't look stretched. (You seem to have been lucky with 800x600! )
              The main point I mean is that I'm happy to use reg hacks, or powerstrip to achieve an onscreen res that gets somewhere near 16:9 - but for example, on my Compaq P4 N1020V laptop with XP pro (With Radeon IGP 340M, 64Mb shared) I cannot access any of the custom resolutions through PowerStrip, not good - on a desktop running NVidia TNT 32Mb and Win98se I *can* access the custom resolutions, *but* everytime I set one, reboot etc - then switch to new custom res the screen just goes blank, again no good.
              I'm just after someone who has a mainboard (or graphics card with TV out) that has successfully tweaked it and managed a near 16:9 TV out - this can help me shortlist what hardware to buy - I don't want to be in a situation where I buy a miniITX board, hook it up and realise there is no way it can be tweaked to run widescreen - that would be a bad move! I've ordered the screen, PSU, USB HD caddy etc etc and started to make the VB frontend so there's no turning back now - ie I'm not here to seek advice on a whim.
              Indeed, anyone who has a new mainboard/gfx card and has tried tweaking it to no avail - please mention it - then I know to strike off that hardware from my shortlist. (eg you may have a VIA EPIA M9000 and have tried everything to get a WideScreen TV out but with no joy, if so I'd like to know so I don't end up buying something that does not do what I require - I have searched the forums but can't find specific enough info, and have emailed suppliers but they haven't got the relevant OS/hardware to be able to confirm to me one way or the other - this is where experience of forum members becomes invaluable.)
              Any information much appreciated.
                The eden Epia 533 and 800 can't be set to resolutions that appoximate 16:9 ratio, i.e 800*480 or 1024*600. I got around the problem by buying a Radeon 9000 64mb DDR card as 3d games at car shows suck big time with the onboard gfx. Means I have DVI, Analog and TV-out too. BTW all radeon cards from 7000 upwards are fully configurable so no probs getting widescreen resolutions via registry or powerstrip methods.
                The Eden M9000 and M10000 use a S3 chipset and several members have reported being able to change to widescreen resolutions in XP. This indicates that the video chipset is capable and hence something like powerstrip and/or registry hacks should work.
                My CarPC install piccies http://www.celica-club.co.uk/cgi-bin...at=561&thumb=1
                  Thankyou
                  So I guess the question now is - do I get the M9000 "as-is" or the EPIA 800 with Radeon 9000...
                  I guess the EPIA/Radeon combo will provide more graphical welly overall (For DIVX playback, maybe odd game)
                  Hmmm...
                    Basically Epia 800 + Radeon 9000 = Just about playable UT2003 at 800*480 with medium detailing and no dynamic lighting.
                    Really depends on your space requirements as you would get better performance from many of the approx 24cm x 25cm micro-atx boards around as they accept P4 or Athlon chips
                    Also, don't know where you reside but in the UK, www.ultim8pc.co.uk stock mini-itx boards that accept seperate CPU's. The Commell LV-670 is a Pentium4 mini-ITX motherboardand the Iwill XP4 is similar to the Shuttle XPC range. You could strip the MB and PSU out of the XP4 and get half decent performance.
                    HTH
                      why dont you get a riser card and throw in a pci video card that supports widescreen
                        Do you know of any [reasonably priced] PCI cards that directly support widescreen then? (as in out-of-the-box) The ones I found were very expensive -
                        I'd rather get a Radeon 7000+ series card and reghack/Powerstrip it.
                        Once I'm sure I'm happy with decision I'll order it
                        - leaning towards 10000 nehemiah & powerstrip at the moment.
                          not off the top of my head but they are out there check out the older tv out ati cards
                          theyll probably be able to do a widescreen
