inverter for electroluminescent backlight
  • inverter for electroluminescent backlight
    I have an LCD display with an electroluminescent backlight, it needs a inverting power supply providing 70-100VAC at 500Hz to 1000 Hz (draws <5mA).
    I have 12V DC from a molex connector. Does anyone know how to make an inverter to provide the power supply the backlight needs?
    Or does anyone know the output of inverters sold with el wire? I was thinking I could use one of them...
    any help appreciated.
    What's the brand of LCD? From what I've seen (using the Search button), a lot of LCD's work on 4.5 to 5 volts DC.
    I would think the 5v supplied by the computer's power supply would do the job. And if the LCD needs 12v, the connector should do the job. Oh yeah, multimeter, multimeter, multimeter...it's your best friend.
    I've got some yellow liquid for your popcorn and it's non-dairy too...
      I'd like to have a little more info about your backlight. It sounds like a good idea to use EL wire, but I've never seen or heard of a backlight like that. From what I know of EL wire, there are quite a few inverters out there that run from 12V. Try www.elwirecheap.com for EL wire stuff. I'm not sure if those 12V inverters they have there are quite strong enough for what you need. The 12V inverter there gives you a frequency that is quite a bit higher than you want and there is nothing said about the voltage, but it should be ok. I'd appreciate any info on your backlight in return (where you got it, how much it costs, etc etc).
      Link: 12V Inverter @ ELWireCheap.com
      "Buckethead's this guy that was raised in a chicken coop and without the bucket on his head, he's helpless"
      - "Really? Oh my god..."
        I have the exact same specs on my 4X20 LCD display. I got it off eBay for $10 bucks and It works great so far. I'm am looking for an inverter as well with no luck yet. If you have found anything out by now let me know.
