Need a reccomendation on AGP vid card with COMP out
  • Need a reccomendation on AGP vid card with COMP out
    After thinking the picture I was getting out of the SVIDEO out of the radeon 8500 I have would be the best I could get I tried my old 8MB AGP ati rage pro with composite out and the difference was very noticeable. I would be happy with this as it is now, but the card is a bit pants for 3D etc and there is one VERY noticeable scrolling type effect/ artifact that spoils it (and there are lots of rainbow type effects on whites). So what card should I get? I want a card with exceptional composite out that's not gonna cost a lot. Are Nvidia cards any better?
    on a side point I would have thought the TVOUT on the radeon 8500 would be pretty damn good- what gives?
    TV-out varies alot on NVIDIA powered cards, each OEM gets to choose what TV out converter chip they use.
    Make sure it's a Made by ATI not Powered by ATI card. 'Powered by' means a third party OEM made the card, and used whatever TV out chip they felt like.
    Also, are you using a S-Video to composite adapter? Those things take down the quality compared to a card that natively outputs Composite.
      I did think the powered by and built by thing might have an influence but I wasn't expecting the difference to be that great. I have a Sapphire 'powered by' card. and I am using the s-video out. That probably explains why the composite is SO much better straight off the 5 year old built by ATI 3D Rage Pro.
      I'm off in search of a Radeon 7500 or something BUILT by ATI with proper composite out- would this be the best solution I could go for?
      thanks for your help
        Pretty much. Keep in mind Radeons don't have an RCA connector on them, so you'll need a breakout cable to get composite. Most ATI cards has what looks like an S-Video port (you can even plug in S-Video and have it work), but it has more pins, so that when you plug in a breakout cable you have native composite.
          if you go for and older radeon they will have rca out... I'm running a Radeon 64MB VIVO pretty much equivalent to the 7200 and have RCA in and out and Svideo out. One of these days i'll upgrade to a new Radeon but lack of $$ keeps me here..
          My brother runs a 9100 (I believe) and says his output off his RCA out is superb as well
          Hope this helps..
          2002 DSM RSX-S
          Custom Car PC Re-design Pending Completion of fiberglassing dash and trunk
          Pics
            thanks.
            so should I be looking at cards with s-video out with a view to using a breakout cable? I don't understand how, as the first reply said, they reduce the quality of the picture. surely it's just the same wires but arranged differently?
              Just my two cents on my past experience these past few weeks...
              My new setup which originally had an EVGA GeForce4 MX 440-8X 64MB VGA/TV left a lot to be desired. The movies I played, for some reason would not size correctly. They looked like they were zoomed in by 250%. I did try to find out why but never figured it out. And this was in ALL programs, ME, M$MP, WinDVD 4 Platnium, Quicktime, and WinAMP. True this card did not have a composite out but I got a quality S-Video to Composite adaptor and it was pretty bad. The screen was wavy and had a little "snow" on the screen. Anyway, I got a new Vid card for my desktop and took the Radeon 7500 from that and swapped it out with the GeForce. I used the 7pin s-video to composite adaptor that came with the my new Radeon 9800. Now my videos play with no issues and the screen, to me, looks a little better...
              Aura MR62 (F and R)
              My Current MP3s
              IamDefiler.com
                I just hooked up the set-top DVD player direct to the screen using proper gold plated cable and the quality is amazing even though it's composite. I want this kind of quality with a TV out on a graphics card. Is there not a definitive card I should be getting?
                  DVD is a diferent story for quality...You will get that quallity on you composite out on your vid. card. It's the text and other apps that don't look so good.
                  Aura MR62 (F and R)
                  My Current MP3s
                  IamDefiler.com
