Mount lcd in dash or console?
  • Mount lcd in dash or console?
    should i put a dscustoms screen where the radio opening is (i think its only 1.75 din though, so fiberglass and bondo will have to help make the opening bigger) or should i put it in a console like the *MOCK* one is below? i know it would probably look a little cleaner in the radio opening, but the console really interests me because i can store my computer in there, relocate my radio to it. it kind of reminds me of a hummer console just because its pretty high and the screen totally faces the driver. thanks -Ryan
    second setup(mock) would be a pimp install, since nobody else has anything like that, but I think it takes up too much space. so if space isnt an issue for you, all i can say - go for it!
    Current Status: For Sale
    Specs
    - 1.5Ghz Toshiba Laptop (available - no screen)
    - Indash Motorized 7" VGA TS
    - DeLorme GPS (sold)
    - Power Inverter (sold)
    - Pioneer HU (sold)
      In Dash
      You should put it in the dash. You do not want to give up all that extra space.
      It looks like 1.75 * DIN, not 1.5 * DIN. I think you have enough room to squeeze it in. Just go to a junk yard and get a second dash plate to work on.
      --Tom
      ME-6000, Lilliput 7" vga + touch, generic GPS, RedHat 9, custom mapping software.
        build your console below your climate control..... that a way you have your cake and eat it too
        ALIBABA - I30 99
        Nemiah M10000, C134
        DVD, 40Gig, 256MB DDR
        GPS, OBD 2, Reverse Cam
        Mute on stereo w I300 car kit
        Liliput 7in w usb touch screen
        Direct connect with BOSE-CD changer
          I would change the colour scheme on the console if you go for it.
          As skassama says, build a smaller console under the CC, the mock you've done is way toooo big.
          also getting a dup dash plate is a good idea, that's what I want to do before I start hacking away my dash.
            ya, i need to go get another front bezel down at the junk yard although the one i already have is kina crappy. here is my idea for the climate controls. i wanted to control them via stepper motors/servos. i would have a digital control on my computer, and the motor or servo would turn the knob to the position that i set it on on the computer. if im going to put a computer in my car, i want to integrate it into my car as much as possible. also, i kina like the console a little higher, cause my arm rest's right on it, and the screen is up closer to my eyes. space isn't really an issue for me. im still definitely thinking about it, just want the board's opinion. thanks -Ryan
              You gonna smuggle aliens in that thing? I'd use the hu's space and put the hu under the dash
              My cars
                smuggle aliens!!! ha ha ha!!! that's great, with that much room i'd go ahead and find a bigscreen tv for it!!!
                Dupe Accounts/Troll
                  I've read on this forum for a long time now, and this is my first post.
                  Here's an idea for you:
                  http://www.termpro.com/cgi-bin/ubb/u...&f=32&t=000571
                  Similar vehicle, you could just modify it to house an LCD screen.
                    I have done both and like the monitor in the dash a bit better. Althought after looking at your mockup I am getting ideas for version 3
                    My 1st setup I installed a Expy. Console in my F150 and placed the computer and screen in the new center console. I was never able to get the angles the way I wanted.
                    So I moved my AC controls to the center console and mounted the screen in the dash. I still need to fininsh the fiberglass on the dash bezel, but it is there and working.
                    Keep us up to date. I am always looking for new ideas for my Truck .
                    Let me know if you have any questions.
                    Jeremy
                    2004 F350 Ext. Cab
                    System not reinstalled in it yet
                      holy **** I gotta learn that some day
                      My cars
                        jeremy, did you have to extend the vacuum lines on your a/c controls when you moved them down?
                          I am not sure, I had the shop that installed my alarm move them down into the hole in the console I cut for the 1st LCD. I thought they would have too extend them (That is why I asked them to do it), but it did not look like they had too.
                          2004 F350 Ext. Cab
                            Be careful. I was just told by Dave at dscustoms that attaching your screen to your dash will void your warranty. I thought the only thing that would do that is opening the case. It seems that these things are so fragile that probably just looking at it crosseyed will void your warranty.
                            Good luck.
                              dave... can i get some input on this? well i guess almost everyone on here has voided their warranty...at least the people with the sweet installs. sometimes you gotta do what ya gotta do. i lifted my truck, im sure that voided the warranty. -Ryan
