lcd ctrl board from deads toshiba laptops
  • lcd ctrl board from deads toshiba laptops
    HI
    I removed form 2 Libretto 110 ct a small board containing a C&T 65548 chip
    with 2 megs of ram in it, this chip can goes to 1024x768.
    Q1 : As someone worked with this chip ???
    Q2 : Does someone have the specs for this chip, is it a enhanced version of the 65545 chip ???
    I want to hook a sharp LQ9d02 ( LQ94d02c ) tft ...
    Im trying to obtain specs or a schematic from toshiba repairs centers ....
    thanks
    http://www.intel.com/design/graphics...s/ds_65548.htm
    That should help
      THANK YOU very much RICKY327 much apreciated, now illl see what can i do with thoses boards ...
        Can I get this to work with a sharp lq10w03 that I got from a toshiba laptop?
          the pdf is talking of LQ10 series... maybe how to connect your screen panel ...
            do you have a pic?? and what do you want for one?
              Im going to scrap a cheap pci vga board to fit this small board, it can be fitted to a isa, a vesa bus, pci or even a direct connection to X86 cpu's, im tring to figure out how the board is wired ..... and there is a way to convert a vga out to a composite/svhs with an ad722 chip ...
                let me know how you make out, the screen I have is a wide screen also, and I would love to get it to work!
                I can not seem to get the pinouts on it!
                  wich brand and screen model do you have ??
                    sharp lq10w03
