Which VGA screen to get?
  • Which VGA screen to get?
    Theres so many threads on this topic, and all have different info, which screen is better? the xenarc or the lilliput? and which screens are curently available? im currently designing my system and would like to get a screen in the next few weeks, so which one should i go with? or whats currently available?
    Pontiac Grand Am
    building CarPC useing BookPC and Lilliput 7 inch TS.
    The one you can get your hands on by the look of it!!!!
      another quick question.. is there any problem with running a long VGA cable from the trunk to the front of the car?
      Pontiac Grand Am
        cable organization is the key for running wires in the car. you should have no problems if you keep power wires, or other "high power" wires away from speaker wires and low voltage signals (i.e. monitor cables)
        run the high power wires on one side of the car, and the low power wires on the other side of the car. if possible, i would even go so far as to run the wires in 3 spots (if you have the room). that way, you could take out the low voltage monitor cable and run it by itself. but if you dont have the space to run 3 sets of leads to and from the trunk, then at least separate the power wires from the rest.
        ~Mike
        Single Member of the "1000 Post and No MP3 Car" Club
        PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
        2000 Cavalier Z24 [###-------] Only 30% Done ... Still
          Go with the Lilliput...
          Aura MR62 (F and R)
          My Current MP3s
          IamDefiler.com
            VGA EXTENSIONS DO NOT WORK!!! ... be very careful, spend the extra for a NAME BRAND, with a GOOD RETURN POLICY ... they are VERY crucial in sending the signal and can REALLY mess it up, significantly! <-- my input
              WTF are you talking about ?
              [H]4 Life
              I'm a lesbian too.
              I am for hire!
                agreed!!!! cable extensions DO WORK.
                ~mike
                  ~mike
                  However make sure you don't get the cheapest one you can find. It will work, but the quality might not be as good.
                  Garry
                  Co-Developer of A.I.M.E.E
                  www.aimee.cc
